Phantomski
Flight distance : 14869882 ft
I have not done this in a while, but is seems that if u get into the GO app, u click the little person, bottom right, then u scroll all the way down, and do settings, u can sign in there. This is also where you tell the app to use usb debugging on android phone.Then you get back to the main screen, click paperplane on the top left, and there u can either press the cloud (top right) to sync, or the little cogwheel (sort of leftish top) to setup what and how to sync, although i think that is ok by default.
Once this is done your old flights will be pulled from dji cloud onto the new device, and new will be uploaded if you had any local.
That is also how you get back your stuff after reinstalling dji go app - on android at least.
I hope i got that procedure right... I have not done the whole process for good 6 months!
main screen
person/settings
settings
logs screen
