mickn666
Hi guys!
Bought my Phantom 2 about a month ago, was flying it yesterday and all of a sudden it just started flying into a direction of a tree, hit the tree, fell 15 metres and hit the deck. Tried to turn it back on, now all I get is 3 flashing red leds when I try to power it on from the remote.
I did a bit of googling, found this http://www.todophantom.com/error ... telligent-battery/.
I opened it up, this was indeed a problem. It was no longer sitting where it should be. I managed to get it to start ONCE by pushing it on, but now it won't start at all. When I checked the voltage coming out of the battery, there was voltage coming out of only one area, the bigger one, as seen below. The other small has no voltage coming out of it. Is this normal? Must I solder the broken wire/cable thing back on?
From my tests, theres no voltage coming out that other area as a standalone battery, nor is there any voltage feeding into that wire that has come loose from the mother board.
Any help woulkd be greatly appreciated!
