Gary Mac
Flight distance : 829885 ft
So, without even touching on the politics, conspiracy theories and folks that can't get past this election...
...this is some of the worst video I've seen. Sorry Op, I realize the intent was probably just to document, not to entertain or wow us with smooth transitions and clear images. However: Your Mavic has an issue with the gimbal. Its not stabilizing properly and the video is very jumpy. Second, you flew with the gimbal cover on in broad daylight. That allowed so many reflections to get in the way that i started to forget about what I was watching and focused on the glare. Finally, and most importantly, this is me of the riskiest flying I've seen to date, perhaps with the exception of the guy who went to 1500 feet over a major city... above the clouds. Flying so close to power lines (probably without visual from the ground) and in such a cluttered area is just asking for trouble... which it appears was found in the final moments of the video. At least it wasn't over top of a crowd of people.
That equipment is most likely headed for a new home or to be sold because it is outdated or unneeded. If it were meant for DC, it would have rolled down the highway with the appropriate soldiers in it. WAY too much work and expense to load and haul a short distance. Regardless, it isn;'t even the right type of equipment for any sort of riot/crowd control.
I hope your Mavic survived the crash. I hope some lessons were learned in the process. Fly safe! |
