AlaskanTides
Flight distance : 1032293 ft
The traditional method has been to try a different motor on that same ESC, Then you see if the problem persist. then try the questionable motor on an ESC that you know is good and see what the results are. If you do Narrow it down to an ESC then you have to Replace it to a new one by soldering it to the FC and PDB, as far as I know this is about the easiest way.
I have never popped open a Phantom and looked at it (Someone with more knowledge then I will hopefully step in) However with these proprietary platforms I would think you're best bet would be to send it to DJI. Reason being is that you're limited on what you can do program wise... You cant exactly open up clean flight and make any needed adjustments, if that becomes required.
