Silvestrone
Flight distance : 464531 ft
A week ago I went in the countryside to get some footage consisting mainly of snowy hills and valley. Everything ok.
Saturday I went back to get more video since there was much more snow than before.
First Episode.
As always, after the checklist, I took off and I keep hovering the P4 at about 3 mt for one or two minutes before sending it away.The P4 suddenly moved forward itself.... OMG !!!! A flyaway !!! ..
I pushed backward the throttle and the P4 stopped.
I thought I could have accidentally touched the right stick (but, No, that wasn't the cause).
Ok... wait a bit more and... the P4 started to fly backwards itself... OMG*2 !!!! now it wants to kill the owner !!!
I pushed forward the throttle and the P4 stopped close enough to be hand grabbed. End of the flight.
I attempted to think what could be happened. I recalled about VPS sensors getting "drunk" when they cannot "see" a clear pattern, but the issue was mainly related to altitude drops, not horizontal movements.
So, doubts start to arise.... What about Ultrasound sensors ? GPS signal was good during the takeoff.
Do VPS and ultrasound sensors override GPS signal ?
I read many threads about behavior of P4 under and over 10 mt of altitude; about issues when flying at low altitude over water surfaces, but once again I expected these issues to related to altitude, not to the horizontal position.
Then I have searched in the device the .txt file for an analysis, but the folder flightrecords seems to contain only logs until november 2016.
BTW.. I attempted a second flight sending the p4 over 10 mt, and everything went smooth this time.
Second Episode
Once again, I wanted to fly at low altitude over a little river.
As you can notice in the video, the P4 suddenly had an altitude drop consisting in about 1-2 meters. When you see the P4 regaining altitude, it was because I immediately pushed the left stick up to regain some altitude...
Once again, I took the P4 back to me and aborted the flight.
It was a crash 100% if I wasn't quick enough.
I recalibrated the IMU in cold environment, then I repeated the take off.
This time I put a pair of gloves under the home point in order to give the VPS some pattern "to see". All went ok this time.
But I wish to understand more about VPS, Ultrasounds sensors, barometric sensors etc etc... I understand the basics (i.e. if the height is > 10 mt then the barometric sensor overrides VPS, or that the VPS doesn't work well in low light conditions or in uniform patterns and so on), but it could be useful to understand more clearly how those sensors cooperate togheter, who overrides who, and above all, how to prevent damages and flyaways in situations similar those I have mentioned in this post.
BTW... I think events similar those mentioned here may explain pretty well why expert pilots loves ATTI mode so much.
At this moment the P4 was flying forward itself... notice the right stick pulled backward to regain ...
Here the P4 is flying back to me (itself) and once again I have to stop it with the right stick move ...
