RicardoGray
![](https://forum44.djicdn.com/data/attachment/common/aa/common_14_usergroup_icon.png) Second Officer
Flight distance : 4356421 ft
If the bin files in no longer on you're sd-card, you will get the prompt. If the file is on the card it should automatically upgrade it. Even if the batteries are up to the latest firmware as is on your PRO, they will work fine in your standard. Your PRO sees the older firmware on the ones from your standard and is advising the update. I don't remember without looking what they added in the later version, I think something about the temperature of the battery on start up. |
