Stock charger (power supply)
1558 3 2015-2-19
dundee
Flight distance : 33550 ft
Thailand
I would like to charge the 2 transmitters at the same time with 1 stock charger.
Possibe to charge 2 TX at same time with Stock charger ?
Ofcourse need to change so i have 2 same plugs (parallel) for TX
Note : found a pic from inside TX battery. ( Thank you Mr. Tomy Thayakorn )
Stock charger Output     26.3V   3.83A         100W
TB 47               LIPO     22.2V   4500mAh     99.90 Wh
TB 48               LIPO     22.8V   5700mAh   129.96 Wh
TX                    LIPO     7.4V     6000mAh      44.4  Wh
2015-2-19
dundee
Thailand
Inspire1 TX-battery
Picture of Inspire1 TX-Battery ( Mr.Tomy Thayakorn)
2015-2-19
DJK
Flight distance : 44154 ft
No reason you can't push out 3800 ma/hr or 100 watts (P=IE) out of the charger into anything you want.
2015-2-19
DJK
I would assume that the batteries in each device has charge rat limiting. I have noticed that the battery charging circuit appears to be on a timer. I have stopped the charge before the lights went out and found the battery already fully charged.
2015-2-19
