altitude toggle switch operate in reverse
491 4 2017-2-2
Gallypro
While flying my P3S for only the second time once liftoff was activated the quad hovered at 4 ' as normal but when I applied the left toggle up (ascend) the quad actually went down (decend).  I then pulled back on the toggle and the quad went up.  Everything in reverse of what it should be.  It worked properly on my first run in a different location.  Would this be some interference or setting issue?
Has anyone ever heard of this or is my machine screwed? Any advise would help.
2017-2-2
Kneepuck
Flight distance : 275105 ft
check in the Go ap menu with the Phantom and r/c both on and make sure you are in Mode 2
2017-2-2
Labroides
Flight distance : 9991457 ft
ps .. the "altitude toggle switch" is called a joystick or left stick.
2017-2-2
Gallypro
Thanks,  I'll try better next time.  Thanks for your help.  Let you know how it goes.
2017-2-2
Gallypro
Kneepuck Posted at 2017-2-2 14:22
Thank you,  I'll try this.
2017-2-2
