New X5 - No Live Feed in DJIgo
1198 5 2017-2-3
MarrisOtter
New Zealand
I just got a new X5 camera and an OSMO handle
I have updated the firmware in the osmo handle and the Inspire 1v2 and in both cases when I attach the X5 camera I dont get to see what the camera is seeing.  The histogram shows that information is being collected through the lens as it changes depending on what I point it.
When I attach my z3 to either device it works fine.
In the firmware section of the osmo it says the encoder firmware failed.  The inspire says everything is fine regarding firmware (apart from a message telling me to cycle the batteries.
I have tried multiple times to re update the firmware on both the osmo and inspire.
I get a message to calibrate my camera.
I was able to take out of focous video and photos - I jsut cant see what I am pointed at on my screen.
Any ideas what I should do before I send the camera back?  Any other info I need to provide you to help me work out the problem?
Got the following text from last time I tried to redo the osmo firmware
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: OSMO_FC550_FW_V01.03.00.40.bin
========== 2014.01.01 00:00:10 remo-con disconnect======
FOCUS NOT CONNECT.
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
I get pretty much the same message when I try and update the Inspire.
Help Please
2017-2-3
Mark Guille
Flight distance : 2031818 ft
Jersey
Are you using the correct firmware for the X5? Click here for X5 Firmware
Hope this helps
Mark .G
2017-2-3
MarrisOtter
New Zealand
Thanks for replying Mark.  Yep, was using the right ones and tried the 1.9.1.3 version too.
2017-2-4
Donnie Stugots
Flight distance : 3636782 ft
MarrisOtter Posted at 2017-2-4 01:20
Ok, when you updated the aircraft did make sure you used the X5 from the "Product Select" drop downlist?  , did you check for "success" on the SD card after updating ?      Also look at the Hidden file  and see if lines 0800 and 1500 say device not detected , if they do  (and you are up to date on the firmware ) the camera will need to go in .
*****DID you make sure that when you went to the DJI download page and that you selected the X5 from the "Product Select "  ( Mark has link above Post ) drop down list ,( sample pic below as well )    .  This is Critical as it defaults to the X3 and not the X5.  If you did not get the proper file than that is your problem , dont bother with my hiden file and just re load the proper FW.
Here is a link to view hidden file
How to View Hidden Files: Tool to  diagnose No signal and SD  Issues
Below is a sample of what I am talking about , notice lines 0800 and 1500,  ( Dont mind the FW version in this example ) also the latest update will be on the VERY BOTTOM of the log, that is where you want to look  on yours .
donnie
2017-2-4
MarrisOtter
New Zealand
Thanks Donnie
I just had another go at updating in the Inspire 1v2.
I reformatted the card, went to teh inspire downloads page, selected the X5 and downloaded "Inspire 1 Pro Firmware v1.10.1.40
2016-12-15" I noted that this file was not zipped as per the instructions.  I put this file onto the freshly formatted SD card and put it in the X5 attached to the Inspire and turned it on without turning on the RC.
It started up and started flashing green and red and beeping.  After less than a minute I got the constant beep of fail and a constant red light.
Shut down and started up again with RC and djigo.
Firmware was showing "abnormal" but the only message was about cycling batteries.
No picture on the screen but histogram etc working.
.txt below
Result: Success.
========== 2014.01.01 00:00:58 remo-con disconnect======
Packet: WM610_FC550_FW_V01.00.00.29.bin
Upgrading ...
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: WM610_FC550_FW_V01.00.00.30_gimb.bin
Upgrading ...
Result: Success.
Packet: WM610_FC550_FW_V01.10.01.40.bin
Upgrading ...
========== 2014.01.01 00:00:06 remo-con disconnect======
Packet: WM610_FC550_FW_V01.09.01.30.bin
========== 2017.02.04 18:23:28 =====================
Upgrading ...
Result: Failed.
========== 2017.02.04 18:48:39 =====================
Result: Failed.
Result: Failed.
Result: Failed.
______________________________________________________________________________________
And the hidden long file
[00013074]========== remo-con disconnect. boot(15) ============
[00013188]Firmware [C:\INFC550Fw1.bin] detected, card sn [0x70ce3fe8].
[00013218][01 00] Firmware upgrade start...
[00012376][01 00] Firmware upgrade finished successfully.
[00012419]Done.
[00012449]Packet [C:\WM610_FC550_FW_V01.00.00.27.bin] resumed, card sn [0xba60878a].
[00012492]Packet vlink 01.00.0027 <-> 01.00.0000.
[00012556]Version checking[2]...
[00012593][01 00][05] v0.33.3962 -> v0.33.3962
[00012623][01 01][00] v0.25.3813 -> v0.33.3962 need upgrade
[00012670][01 04][00] v0.1.10297 -> v0.1.3956
[00012707][04 00][00] v1.26.0.44 -> v1.26.0.49 need upgrade.
[00012769][03 05][00] v34.1.0.5 -> v34.1.0.5
[00012827][03 06][00] v2.3.0.13 -> v2.3.1.0 need upgrade.
[00012907][05 00][00] v3.0.6.1 -> v3.0.6.1
[00012946][08 00][00] v2.14.9.17 -> v2.14.9.17
[00012998][09 00][00] v1.8.0.0 -> v1.8.0.0
[00013069][11 00][00] v3.7.15.10 -> v3.7.15.10
[00013147][12 00][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00013248][12 01][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00013307][12 02][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00013387][12 03][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00013469][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013526][17 00][00] v1.1.0.4 -> v1.1.0.4
[00013626][17 01][00] v2.0.0.8 -> v2.0.0.8
[00013670][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013700]Done.
[00013731]Firmware upgrading[2]...
[00013819][01 01] Firmware upgrade start...
[00044100][01 01] Firmware upgrade finished successfully.
[00044143][12 00] Firmware upgrade start...
[00099801][12 00] Firmware upgrade finished successfully.
[00099844][12 01] Firmware upgrade start...
[00156341][12 01] Firmware upgrade finished successfully.
[00156385][12 02] Firmware upgrade start...
[00212719][12 02] Firmware upgrade finished successfully.
[00212769][12 03] Firmware upgrade start...
[00270058][12 03] Firmware upgrade finished successfully.
[00270194][03 06] Firmware upgrade start...
[00509391][03 06] Firmware upgrade finished successfully.
[00509549][04 00] Firmware upgrade start...
[00581152][04 00] Firmware upgrade finished successfully.
[00581185]Done.
[00581218]Version checking[3]...
[00581256][01 00][05] v0.33.3962 -> v0.33.3962
[00581289][01 01][05] v0.33.3962 -> v0.33.3962
[00581338][01 04][00] v0.1.10297 -> v0.1.3956
[00581410][04 00][05] v1.26.0.49 -> v1.26.0.49
[00581471][03 05][00] v34.1.0.5 -> v34.1.0.5
[00581537][03 06][05] v2.3.1.0 -> v2.3.1.0
[00581611][05 00][00] v3.0.6.1 -> v3.0.6.1
[00581655][08 00][00] v2.14.9.17 -> v2.14.9.17
[00581702][09 00][00] v1.8.0.0 -> v1.8.0.0
[00581772][11 00][00] v3.7.15.10 -> v3.7.15.10
[00581852][12 00][05] v1.11.0.0 -> v1.11.0.0
[00581952][12 01][05] v1.11.0.0 -> v1.11.0.0
[00582052][12 02][05] v1.11.0.0 -> v1.11.0.0
[00582138][12 03][05] v1.11.0.0 -> v1.11.0.0
[00583039][15 00][00] v1.1.2.0 -> v1.1.2.0
[00583091][17 00][00] v1.1.0.4 -> v1.1.0.4
[00583191][17 01][00] v2.0.0.8 -> v2.0.0.8
[00583239][19 00][00] v1.0.8.96 -> v1.0.8.96
[00583271]Packet upgrade finish successfully.
[00058963]========== remo-con disconnect. boot(15) ============
[00059010]Packet [C:\WM610_FC550_FW_V01.00.00.29.bin] detected, card sn [0xba60863a].
[00059057]Packet upgrade start...
[00059097]Packet checking...
[00059159]Packet vlink 01.00.0029 <-> 01.00.0000.
[00059207]Done.
[00059241]Version checking[1]...
[00059285][01 00][00] v0.33.3962 -> v0.34.3973 need upgrade
[00059330][01 01][00] v0.33.3962 -> v0.34.3973 need upgrade
[00059381][01 04][00] v0.1.10297 -> v0.1.3977 need upgrade
[00059430][04 00][00] v1.26.0.49 -> v1.27.0.1 need upgrade.
[00059493][03 05][00] v34.1.0.5 -> v34.1.0.5 need upgrade.
[00059567][03 06][00] v2.3.1.0 -> v2.3.1.0 need upgrade.
[00059647][05 00][00] v3.0.6.1 -> v3.0.6.1 need upgrade.
[00059695][08 00][00] v2.14.9.17 -> v2.14.9.17 need upgrade.
[00059758][09 00][00] v1.8.0.0 -> v1.8.0.0 need upgrade.
[00059830][11 00][00] v3.7.15.10 -> v3.7.15.10 need upgrade.
[00059930][12 00][00] v1.11.0.0 -> v1.11.0.0 need upgrade.
[00060131][12 01][00] v1.11.0.0 -> v1.11.0.0 need upgrade.
[00060208][12 02][00] v1.11.0.0 -> v1.11.0.0 need upgrade.
[00060308][12 03][00] v1.11.0.0 -> v1.11.0.0 need upgrade.
[00061073][15 00][00] v1.1.2.0 -> v1.1.2.0 need upgrade.
[00061131][17 00][00] v1.1.0.4 -> v1.1.0.4 need upgrade.
[00061247][17 01][00] v2.0.0.8 -> v2.0.0.8 need upgrade.
[00061293][19 00][00] v1.0.8.96 -> v1.0.8.96 need upgrade.
[00061331]Done.
[00063366]Waiting for user confirm...
[00073419]Timeout, start upgrade automatically.
[00073496]Firmware upgrading[1]...
[00078998][01 00] Firmware upgrade start...
[00012491][01 00] Firmware upgrade finished successfully.
[00012529]Done.
[00012565]Packet [C:\WM610_FC550_FW_V01.00.00.29.bin] resumed, card sn [0xba60863a].
[00012619]Packet vlink 01.00.0029 <-> 01.00.0000.
[00012658]Version checking[2]...
[00012693][01 00][05] v0.34.3973 -> v0.34.3973 need upgrade
[00012740][01 01][00] v0.33.3962 -> v0.34.3973 need upgrade
[00012790][01 04][00] v0.1.10297 -> v0.1.3977 need upgrade
[00012837][04 00][00] v1.26.0.49 -> v1.27.0.1 need upgrade.
[00012926][03 05][00] v34.1.0.5 -> v34.1.0.5 need upgrade.
[00012986][03 06][00] v2.3.1.0 -> v2.3.1.0 need upgrade.
[00013066][05 00][00] v3.0.6.1 -> v3.0.6.1 need upgrade.
[00013130][08 00][00] v2.14.9.17 -> v2.14.9.17 need upgrade.
[00013175][09 00][00] v1.8.0.0 -> v1.8.0.0 need upgrade.
[00013266][11 00][00] v3.7.15.10 -> v3.7.15.10 need upgrade.
[00013366][12 00][00] v1.11.0.0 -> v1.11.0.0 need upgrade.
[00013446][12 01][00] v1.11.0.0 -> v1.11.0.0 need upgrade.
[00013566][12 02][00] v1.11.0.0 -> v1.11.0.0 need upgrade.
[00013646][12 03][00] v1.11.0.0 -> v1.11.0.0 need upgrade.
[00015167][15 00][00] v1.1.2.0 -> v1.1.2.0 need upgrade.
[00015226][17 00][00] v1.1.0.4 -> v1.1.0.4 need upgrade.
[00015326][17 01][00] v2.0.0.8 -> v2.0.0.8 need upgrade.
[00015370][19 00][00] v1.0.8.96 -> v1.0.8.96 need upgrade.
[00015407]Done.
[00015447]Firmware upgrading[2]...
[00015619][01 01] Firmware upgrade start...
[00045924][01 01] Firmware upgrade finished successfully.
[00045979][01 04] Firmware upgrade start...
[00083963][01 04] Firmware upgrade finished successfully.
[00084699][08 00] Firmware upgrade start...
[00643372][08 00] Firmware upgrade finished successfully.
[00643424][12 00] Firmware upgrade start...
[00699573][12 00] Firmware upgrade finished successfully.
[00699627][12 01] Firmware upgrade start...
[00757584][12 01] Firmware upgrade finished successfully.
[00757632][12 02] Firmware upgrade start...
[00814388][12 02] Firmware upgrade finished successfully.
[00814446][12 03] Firmware upgrade start...
[00872200][12 03] Firmware upgrade finished successfully.
[00872252][03 05] Firmware upgrade start...
[00929603][03 05] Firmware upgrade finished successfully.
[00929751][03 06] Firmware upgrade start...
[01177930][03 06] Firmware upgrade finished successfully.
[01177991][17 00] Firmware upgrade start...
[01240313][17 00] Firmware upgrade finished successfully.
[01240365][17 01] Firmware upgrade start...
[01294006][17 01] Firmware upgrade finished successfully.
[01294050][11 00] Firmware upgrade start...
[01331449][11 00] Firmware upgrade finish failed (step = 4, err = 0xf4, idx = 66, los = 1, ng = 29).
[01361504][05 00] Firmware upgrade start...
[01406008][05 00] Firmware upgrade finished successfully.
[01406058][15 00] Firmware upgrade start...
[01444208][15 00] Firmware upgrade finished successfully.
[01446921][19 00] Firmware upgrade start...
[01676284][19 00] Firmware upgrade finished successfully.
[01676340][09 00] Firmware upgrade start...
[01728839][09 00] Firmware upgrade finished successfully.
[01728914][04 00] Firmware upgrade start...
[01801389][04 00] Firmware upgrade finished successfully.
[01801432]Done.
[01801465]Version checking[3]...
[01801506][01 00][05] v0.34.3973 -> v0.34.3973 need upgrade
[01801542][01 01][05] v0.34.3973 -> v0.34.3973 need upgrade
[01801584][01 04][05] v0.1.3977 -> v0.1.3977 need upgrade
[01801773][04 00][05] v1.27.0.1 -> v1.27.0.1 need upgrade.
[01801855][03 05][05] v34.1.0.5 -> v34.1.0.5 need upgrade.
[01801935][03 06][05] v2.3.1.0 -> v2.3.1.0 need upgrade.
[01802015][05 00][05] v3.0.6.1 -> v3.0.6.1 need upgrade.
[01802062][08 00][05] v2.14.9.17 -> v2.14.9.17 need upgrade.
[01802139][09 00][05] v1.8.0.0 -> v1.8.0.0 need upgrade.
[01802215][11 00][00] v0.0.0.0 -> v3.7.15.10 need upgrade.
[01802296][12 00][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01802395][12 01][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01802495][12 02][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01802595][12 03][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01802706][15 00][05] v1.1.2.0 -> v1.1.2.0 need upgrade.
[01802774][17 00][05] v1.1.0.4 -> v1.1.0.4 need upgrade.
[01802875][17 01][05] v2.0.0.8 -> v2.0.0.8 need upgrade.
[01802951][19 00][05] v1.0.8.96 -> v1.0.8.96 need upgrade.
[01802990]Done.
[01803033]Firmware upgrading[3]...
[01803079][11 00] Firmware upgrade start...
[01883970][11 00] Firmware upgrade finished successfully.
[01884014]Done.
[01884049]Version checking[4]...
[01884094][01 00][05] v0.34.3973 -> v0.34.3973 need upgrade
[01884141][01 01][05] v0.34.3973 -> v0.34.3973 need upgrade
[01884187][01 04][05] v0.1.3977 -> v0.1.3977 need upgrade
[01884248][04 00][05] v1.27.0.1 -> v1.27.0.1 need upgrade.
[01884333][03 05][05] v34.1.0.5 -> v34.1.0.5 need upgrade.
[01884393][03 06][05] v2.3.1.0 -> v2.3.1.0 need upgrade.
[01884473][05 00][05] v3.0.6.1 -> v3.0.6.1 need upgrade.
[01884571][08 00][05] v2.14.9.17 -> v2.14.9.17 need upgrade.
[01884637][09 00][05] v1.8.0.0 -> v1.8.0.0 need upgrade.
[01884737][11 00][05] v3.7.15.10 -> v3.7.15.10 need upgrade.
[01884832][12 00][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01884915][12 01][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01885015][12 02][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01885093][12 03][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01885187][15 00][05] v1.1.2.0 -> v1.1.2.0 need upgrade.
[01885333][17 00][05] v1.1.0.4 -> v1.1.0.4 need upgrade.
[01885433][17 01][05] v2.0.0.8 -> v2.0.0.8 need upgrade.
[01885553][19 00][05] v1.0.8.96 -> v1.0.8.96 need upgrade.
[01885597]Packet upgrade finish successfully.
[00013266]========== remo-con disconnect. boot(15) ============
[00013302]Firmware [C:\INCAMBCPUFw1.bin] detected, card sn [0x95a44e8f].
[00013336][01 04] Firmware upgrade start...
[00049521][01 04] Firmware upgrade finished successfully.
[00049559]Done.
[00014816]========== remo-con disconnect. boot(15) ============
[00014859]Firmware [C:\INCAMBCPUFw1.bin] detected, card sn [0x95a44e9b].
[00014898][01 04] Firmware upgrade start...
[00048902][01 04] Firmware upgrade finished successfully.
[00048940]Done.
[00013639]========== remo-con disconnect. boot(15) ============
[00013678]Firmware [C:\INCAMBCPUFw1.bin] detected, card sn [0x97a65259].
[00013714][01 04] Firmware upgrade start...
[00050984][01 04] Firmware upgrade finished successfully.
[00051026]Done.
[00013038]========== remo-con disconnect. boot(15) ============
[00013074]Packet [C:\WM610_FC550_FW_V01.00.00.30_gimb.bin] detected, card sn [0x280f3cc2].
[00013113]Packet upgrade start...
[00013153]Packet checking...
[00013189]Packet vlink 01.00.0030 <-> 01.00.0030.
[00013224]Record vlink 01.00.0029 <-> 01.00.0000 (flow = 0).
[00013260]Done.
[00013296]Version checking[1]...
[00013332][01 00][00] v0.34.3973 -> v0.34.3973
[00013368][01 01][00] v0.34.3973 -> v0.34.3973
[00013413][01 04][00] v0.1.3964 -> v0.1.3977 need upgrade
[00013456][04 00][00] v1.28.0.0 -> v1.28.0.5 need upgrade.
[00013507][08 00][00] v2.14.9.17 -> v2.14.9.17
[00013544]Done.
[00015581]Waiting for user confirm...
[00025623]Timeout, start upgrade automatically.
[00025700]Firmware upgrading[1]...
[00025745][01 04] Firmware upgrade start...
[00063023][01 04] Firmware upgrade finished successfully.
[00063082][04 00] Firmware upgrade start...
[00133076][04 00] Firmware upgrade finished successfully.
[00133205]Done.
[00133244]Version checking[2]...
[00133280][01 00][00] v0.34.3973 -> v0.34.3973
[00133318][01 01][00] v0.34.3973 -> v0.34.3973
[00133361][01 04][05] v0.1.3977 -> v0.1.3977
[00133405][04 00][05] v1.28.0.5 -> v1.28.0.5
[00133451][08 00][00] v2.14.9.17 -> v2.14.9.17
[00133488]Packet upgrade finish successfully.
[00014649]========== remo-con disconnect. boot(15) ============
[00014686]Packet [C:\WM610_FC550_FW_V01.10.01.40.bin] detected, card sn [0x5310633e].
[00014727]Packet upgrade start...
[00014772]Packet checking...
[00014815]Packet vlink 01.10.0140 <-> 01.09.0130.
[00014853]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00014893]Done.
[00014933]Version checking[1]...
[00014977][04 00][00] v1.28.0.5 -> v1.30.1.28 need upgrade.
[00027518][08 00][00] device not detected.
[00027563][01 00][00] v0.34.3973 -> v1.29.5379 need upgrade
[00027600][01 01][00] v0.34.3973 -> v1.29.5379 need upgrade
[00040148][01 04][00] device not detected.
[00040238][03 05][00] v34.1.0.5 -> v34.1.0.5
[00040318][03 06][00] v2.4.20.18 -> v2.4.20.28 need upgrade.
[00040398][05 00][00] v3.0.6.2 -> v3.0.6.2
[00040468][09 00][00] v3.0.0.4 -> v3.1.0.0 need upgrade.
[00040558][11 00][00] v3.9.0.0 -> v3.9.0.0
[00040638][12 00][00] v1.11.0.0 -> v1.11.0.0
[00040738][12 01][00] v1.11.0.0 -> v1.11.0.0
[00040818][12 02][00] v1.11.0.0 -> v1.11.0.0
[00040918][12 03][00] v1.11.0.0 -> v1.11.0.0
[00053458][15 00][00] device not detected.
[00053518][17 00][00] v1.1.0.8 -> v1.1.0.8
[00053617][17 01][00] v2.0.1.6 -> v2.0.1.6
[00053677][19 00][00] v1.0.8.96 -> v1.0.8.96
[00053717]Done.
[00055758]Waiting for user confirm...
[00065795]Timeout, start upgrade automatically.
[00065880]Firmware upgrading[1]...
[00071540][01 00] Firmware upgrade start...
[00007853][01 00] Firmware upgrade finished successfully.
[00007898]Done.
[00007938]Packet [C:\WM610_FC550_FW_V01.10.01.40.bin] resumed, card sn [0x5310633e].
[00008060]Packet vlink 01.10.0140 <-> 01.09.0130.
[00008107]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00008147]Version checking[2]...
[00008214][04 00][00] v1.28.0.5 -> v1.30.1.28 need upgrade.
[00020752][08 00][00] device not detected.
[00020791][01 00][05] v1.29.5379 -> v1.29.5379
[00020828][01 01][00] v0.34.3973 -> v1.29.5379 need upgrade
[00023367][01 04][00] device not detected, reset device.
[00033904][01 04][00] device not detected, reset device.
[00044445][01 04][00] device not detected, reset device.
[00054982][01 04][00] device not detected, reset device.
[00065521][01 04][00] device not detected.
[00065780][03 05][00] v34.1.0.5 -> v34.1.0.5
[00065865][03 06][00] v2.4.20.18 -> v2.4.20.28 need upgrade.
[00065980][05 00][00] v3.0.6.2 -> v3.0.6.2
[00066029][09 00][00] v3.0.0.4 -> v3.1.0.0 need upgrade.
[00066119][11 00][00] v3.9.0.0 -> v3.9.0.0
[00066220][12 00][00] v1.11.0.0 -> v1.11.0.0
[00066300][12 01][00] v1.11.0.0 -> v1.11.0.0
[00066400][12 02][00] v1.11.0.0 -> v1.11.0.0
[00066480][12 03][00] v1.11.0.0 -> v1.11.0.0
[00079018][15 00][00] device not detected.
[00079080][17 00][00] v1.1.0.8 -> v1.1.0.8
[00079180][17 01][00] v2.0.1.6 -> v2.0.1.6
[00079230][19 00][00] v1.0.8.96 -> v1.0.8.96
[00079292]Done.
[00079329]Firmware upgrading[2]...
[00079436][01 01] Firmware upgrade start...
[00089704][01 01] Firmware upgrade finished successfully.
[00089842][03 06] Firmware upgrade start...
[00326711][03 06] Firmware upgrade finished successfully.
[00326768][09 00] Firmware upgrade start...
[00360936][09 00] Firmware upgrade finished successfully.
[00361005][04 00] Firmware upgrade start...
[00414267][04 00] Firmware upgrade finished successfully.
[00414310]Done.
[00414352]Version checking[3]...
[00414396][04 00][05] v1.30.1.28 -> v1.30.1.28
[00426936][08 00][00] device not detected.
[00426975][01 00][05] v1.29.5379 -> v1.29.5379
[00427014][01 01][05] v1.29.5379 -> v1.29.5379
[00429551][01 04][00] device not detected, reset device.
[00006691]========== remo-con disconnect. boot(15) ============
[00006754]Packet [C:\WM610_FC550_FW_V01.09.01.30.bin] detected, card sn [0x5310633e].
[00006813]Packet upgrade start...
[00006861]Packet checking...
[00006903]Packet vlink 01.09.0130 <-> 01.08.0100.
[00006948]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00006990]Done.
[00007039]Version checking[1]...
[00019582][08 00][00] device not detected.
[00019630][01 00][00] v1.29.5379 -> v1.27.5134
[00019674][01 01][00] v1.29.5379 -> v1.27.5134
[00022219][01 04][00] device not detected, reset device.
[00032761][01 04][00] device not detected, reset device.
[00043302][01 04][00] device not detected, reset device.
[00006780]========== remo-con disconnect. boot(15) ============
[00006825]Packet [C:\WM610_FC550_FW_V01.10.01.40.bin] detected, card sn [0x5310633e].
[00006874]Packet upgrade start...
[00006946]Packet checking...
[00006999]Packet vlink 01.10.0140 <-> 01.09.0130.
[00007046]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00007095]Done.
[00007153]Version checking[1]...
[00007221][04 00][00] v1.30.1.28 -> v1.30.1.28
[00006590]========== 2017.02.04 18:23:28. boot(15) ============
[00006637]Packet [C:\WM610_FC550_FW_V01.10.01.40.bin] detected, card sn [0x5310633e].
[00006683]Packet upgrade start...
[00006740]Packet checking...
[00006793]Packet vlink 01.10.0140 <-> 01.09.0130.
[00006860]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00006906]Done.
[00006956]Version checking[1]...
[00007006][04 00][00] v1.30.1.28 -> v1.30.1.28
[00019550][08 00][00] device not detected.
[00019592][01 00][00] v1.29.5379 -> v1.29.5379
[00019638][01 01][00] v1.29.5379 -> v1.29.5379
[00022179][01 04][00] device not detected, reset device.
[00030325][01 04][00] v0.1.3977 -> v0.5.5085 need upgrade
[00030425][03 05][00] v34.1.0.5 -> v34.1.0.5
[00030505][03 06][00] v2.4.20.28 -> v2.4.20.28
[00030613][05 00][00] v3.0.6.2 -> v3.0.6.2
[00030669][09 00][00] v3.1.0.0 -> v3.1.0.0
[00030865][11 00][00] v3.9.0.0 -> v3.9.0.0
[00030964][12 00][00] v1.11.0.0 -> v1.11.0.0
[00031045][12 01][00] v1.11.0.0 -> v1.11.0.0
[00031145][12 02][00] v1.11.0.0 -> v1.11.0.0
[00031245][12 03][00] v1.11.0.0 -> v1.11.0.0
[00043787][15 00][00] device not detected.
[00043865][17 00][00] v1.1.0.8 -> v1.1.0.8
[00043965][17 01][00] v2.0.1.6 -> v2.0.1.6
[00044019][19 00][00] v1.0.8.96 -> v1.0.8.96
[00044064]Done.
[00047616]Waiting for user confirm...
[00057660]Timeout, start upgrade automatically.
[00057745]Firmware upgrading[1]...
[00057805][01 04] Firmware upgrade start...
[00093924][01 04] Firmware upgrade finish failed (step = 3, err = 0xaa).
[00103970]Done.
[00104012]Version checking[2]...
[00104069][04 00][00] v1.30.1.28 -> v1.30.1.28
[00116613][08 00][00] device not detected.
[00116662][01 00][00] v1.29.5379 -> v1.29.5379
[00116704][01 01][00] v1.29.5379 -> v1.29.5379
[00119249][01 04][06] device not detected, reset device.
[00129793][01 04][06] device not detected, reset device.
[00137939][01 04][00] v0.0.0 -> v0.5.5085 need upgrade
[00138004][03 05][00] v34.1.0.5 -> v34.1.0.5
[00138084][03 06][00] v2.4.20.28 -> v2.4.20.28
[00138164][05 00][00] v3.0.6.2 -> v3.0.6.2
[00138217][09 00][00] v3.1.0.0 -> v3.1.0.0
[00138304][11 00][00] v3.9.0.0 -> v3.9.0.0
[00138424][12 00][00] v1.11.0.0 -> v1.11.0.0
[00138523][12 01][00] v1.11.0.0 -> v1.11.0.0
[00138623][12 02][00] v1.11.0.0 -> v1.11.0.0
[00138723][12 03][00] v1.11.0.0 -> v1.11.0.0
[00151282][15 00][00] device not detected.
[00151344][17 00][00] v1.1.0.8 -> v1.1.0.8
[00151443][17 01][00] v2.0.1.6 -> v2.0.1.6
[00151502][19 00][00] v1.0.8.96 -> v1.0.8.96
[00151548]Done.
[00151590]Firmware upgrading[2]...
[00151642][01 04] Firmware upgrade start...
[00176962][01 04] Firmware upgrade finished successfully.
[00177006]Done.
[00177051]Version checking[3]...
[00177099][04 00][00] v1.30.1.28 -> v1.30.1.28
[00189646][08 00][00] device not detected.
[00189691][01 00][00] v1.29.5379 -> v1.29.5379
[00189813][01 01][00] v1.29.5379 -> v1.29.5379
[00192360][01 04][05] device not detected, reset device.
[00200505][01 04][05] v0.5.5085 -> v0.5.5085
[00200610][03 05][00] v34.1.0.5 -> v34.1.0.5
[00200681][03 06][00] v2.4.20.28 -> v2.4.20.28
[00200761][05 00][00] v3.0.6.2 -> v3.0.6.2
[00200815][09 00][00] v3.1.0.0 -> v3.1.0.0
[00200902][11 00][00] v3.9.0.0 -> v3.9.0.0
[00201022][12 00][00] v1.11.0.0 -> v1.11.0.0
[00201122][12 01][00] v1.11.0.0 -> v1.11.0.0
[00201241][12 02][00] v1.11.0.0 -> v1.11.0.0
[00201341][12 03][00] v1.11.0.0 -> v1.11.0.0
[00213885][15 00][00] device not detected.
[00213961][17 00][00] v1.1.0.8 -> v1.1.0.8
[00214062][17 01][00] v2.0.1.6 -> v2.0.1.6
[00214122][19 00][00] v1.0.8.96 -> v1.0.8.96
[00214172]Packet upgrade failed at version checking.
[00006638]========== 2017.02.04 18:48:39. boot(15) ============
[00006689]Packet [C:\WM610_FC550_FW_V01.10.01.40.bin] detected, card sn [0x5310633e].
[00006735]Packet upgrade start...
[00006809]Packet checking...
[00006859]Packet vlink 01.10.0140 <-> 01.09.0130.
[00006919]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00006982]Done.
[00007033]Version checking[1]...
[00007085][04 00][00] v1.30.1.28 -> v1.30.1.28
[00019627][08 00][00] device not detected.
[00019675][01 00][00] v1.29.5379 -> v1.29.5379
[00019724][01 01][00] v1.29.5379 -> v1.29.5379
[00019782][01 04][00] v0.5.5085 -> v0.5.5085
[00019873][03 05][00] v34.1.0.5 -> v34.1.0.5
[00020033][03 06][00] v2.4.20.28 -> v2.4.20.28
[00020095][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020163][09 00][00] v3.1.0.0 -> v3.1.0.0
[00020254][11 00][00] v3.9.0.0 -> v3.9.0.0
[00020333][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020414][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020514][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020615][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033163][15 00][00] device not detected.
[00035734][17 00][00] v1.1.0.8 -> v1.1.0.8
[00035853][17 01][00] v2.0.1.6 -> v2.0.1.6
[00036020][19 00][00] v1.0.8.96 -> v1.0.8.96
[00038075]Packet upgrade failed at version checking.
[00006701]========== remo-con disconnect. boot(15) ============
[00006749]Packet [C:\WM610_FC550_FW_V01.10.01.40.bin] detected, card sn [0x5310633e].
[00006802]Packet upgrade start...
[00006855]Packet checking...
[00006906]Packet vlink 01.10.0140 <-> 01.09.0130.
[00006953]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00007001]Done.
[00007050]Version checking[1]...
[00007109][04 00][00] v1.30.1.28 -> v1.30.1.28
[00019660][08 00][00] device not detected.
[00019709][01 00][00] v1.29.5379 -> v1.29.5379
[00019753][01 01][00] v1.29.5379 -> v1.29.5379
[00019809][01 04][00] v0.5.5085 -> v0.5.5085
[00019903][03 05][00] v34.1.0.5 -> v34.1.0.5
[00020003][03 06][00] v2.4.20.28 -> v2.4.20.28
[00020103][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020157][09 00][00] v3.1.0.0 -> v3.1.0.0
[00020243][11 00][00] v3.9.0.0 -> v3.9.0.0
[00020324][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020403][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020524][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020604][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033148][15 00][00] device not detected.
[00033224][17 00][00] v1.1.0.8 -> v1.1.0.8
[00033344][17 01][00] v2.0.1.6 -> v2.0.1.6
[00033398][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035451]Packet upgrade failed at version checking.
[00006818]========== remo-con disconnect. boot(15) ============
[00006874]Packet [C:\WM610_FC550_FW_V01.10.01.40.bin] detected, card sn [0x5310633e].
[00006922]Packet upgrade start...
[00006980]Packet checking...
[00007033]Packet vlink 01.10.0140 <-> 01.09.0130.
[00007095]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00007143]Done.
[00007199]Version checking[1]...
[00007255][04 00][00] v1.30.1.28 -> v1.30.1.28
[00019817][08 00][00] device not detected.
[00019861][01 00][00] v1.29.5379 -> v1.29.5379
[00019914][01 01][00] v1.29.5379 -> v1.29.5379
[00019980][01 04][00] v0.5.5085 -> v0.5.5085
[00020079][03 05][00] v34.1.0.5 -> v34.1.0.5
[00020279][03 06][00] v2.4.20.28 -> v2.4.20.28
[00020379][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020437][09 00][00] v3.1.0.0 -> v3.1.0.0
[00020532][11 00][00] v3.9.0.0 -> v3.9.0.0
[00020632][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020752][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020852][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020952][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033503][15 00][00] device not detected.
[00033593][17 00][00] v1.1.0.8 -> v1.1.0.8
[00033711][17 01][00] v2.0.1.6 -> v2.0.1.6
[00033793][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035839]Packet upgrade failed at version checking.
I'm seeing plenty of "device not detected".  My Inspire and my osmo work with my Z3 camera.  Do I need to send the X5 camera back to where I brought it from?  (its brand new)?
2017-2-4
Donnie Stugots
MarrisOtter Posted at 2017-2-4 14:48
Thanks Donnie
Yes you do have to send it for repair ( sorry ) This can happen for a number of reasons, I see it more often with owners of the Osmo .  I would just contact who ever you purchased it from and explain the error and that your system works fine with the Z3 but not the X5.  It is normally a very simple reprogram of the system, very rarely does the " Video Module " on the X5 actually break  ( This is what is causing the "Device Not Detected" is a failed or corrupted video module on the X5 ).
Make sure when you update the AC ( in the future )  that you never have the RC transmitter On , that can cause  ( Device not Detected ) this among othere things .
donnie
2017-2-5
