Grizz 1
Flight distance : 120066 ft
charging both at the same time should not be a an issue. i do it lots and never had a problem. before you fly next time or even inside, power up your pad, rc and aircraft and press the three little dots in upper right corner of the screen. in that menu look for the battery icon and open that and look at the status of all the cells, they should all be green and close to the same voltage. if they are all green then you shouldn't have any problems. hope this helps ! |
