endotherm
Flight distance : 503241 ft
The "intelligent" part of the Intelligent Flight Battery takes care of all that for you. It will put the battery into the optimum storage level for the best life of the battery. Storing fully charged batteries for a long time is not a good thing, they are prone to swell and become damaged. Completely flattening a battery is also not good for it, and it will not store well at that charge either. Approximately half-charged is optimum for storage. Different chemistries have different requirements, and older batteries like NiCd may have required full disharge or a different charging regime. The more modern Lithium batteries have a different handling requirement. You are safe letting the intelligent circuitry of DJI batteries take care of it for you. In your case, it would start discharging a fully charged battery you have put into storage after a day or so (as long as you don't press the button on the battery, or the timer will restart). It will take a couple of days to slowly self-discharge to the optimum level of 50-60%. It will get warm as it discharges the extra capacity, but not hot enough to be concerned that it will melt anything or cause a fire. |
