WindSoul
RUDIMAN Posted at 2017-2-24 10:43
The only thing I noticed is that the longer the flight ..the more the values are off. First minutes everything seems to be fine..then it start.. I made several landings to reset the the values but that doesn,t help. I looks like the warmer the drone gets the more the value is off..
I have noticed many people jump at recalibrating as if that would restore the defaults. I believe recalibrating needs performed only when requested by the drone and while essentially benign, i dont see a purpose with unnecessarily unrequired calibrating. my drone was never calibrated at my initative. it required compass calibration once and it was done. this is how is supposed to be and im glad to report that three months into ownership, this is how it is with my drone.
Revenons a nos moutons,
what you essentially need to do is send the flight records to DJI and let them decide if there's a problem.
What I would do:
1. i would record a 10+minutes flight:
1.1. take the drone out, give it 2 minutes to acclimatize. make sure the flight mode is set to P.
1.2. connect, power up, start recording, acknowledge no errors or warnings. auto take-off. observe hovering at 1.2m and altitude indications for say a minute. if drone looses altitude i would correct that. check that RTH altitude is set above land features.
1.3. do some loops within visual range, at an altitude of 15-20m above land features. observe and correct any tendency of loosing altitude.
1.4. do some hovering at different altitudes. observe if the drone can maintain altitude, correct if needed.
1.5. end the flight either with RTH (if the drone is within visual range but farther than 20m from RTH location, also RTH path is clear of obstacles) or with manual landing.
2. provide the flight record of that particular flight (make it available either to this thread or to DJI directly).
the flight record can indicate abnormalities, for example: if you let it hover and the altitude indication starts drifting, then DJI could tell if that is to be expected or not.
Please have in mind that my message only contains recommendations and I am not pretending this is the best way, or the safest way for you to proceed in solving your problem. I want to be helpful but I realize I'm not there and can not assume responsibility if by following my advice you are getting any negative results. take it with a bit of salt, that is. see if that fits your understanding and adjust it with your own safety precautions.
