IMU Calibration
1937 7 2015-2-22
snathla
Flight distance : 5045295 ft
Do you have to re-calibrate IMU everytime you fly or only at certain points (i.e. new location, change of battery, etc)?
2015-2-22
svencool
Flight distance : 6690 ft
I read somewhere that the only time a new IMU cal was suppose to be done was,  I would do one if you just unboxed your craft and are fixing to fly for the first time. Also if you notice any drifting in GPS mode then do another IMU cal. I have almost 40 flights I've maybe done one 3-4 times. Once when first got it and once when I went to another state to fly, Once when I noticed it drifting which only happened once. Maybe 1 other time. I check my settings before every flight and if they are with in the normal parameters then I don't worry about it. Hope this helps. If you do a search you will find lots of info on here as it has been discussed to death lol. But its your craft so do what you think you need to do. Don't just take my word for it
Mike
2015-2-22
p760302.hotmail
From dealer, they said once a day fine (IMU cal).
Don't have to do BTW battery.
But you need compass cal when you change location far from previous spot.
Enjoy your bird.
2015-2-22
svencool
Here is something I saved so it might help you......
2015-2-22
snathla
svencool Posted at 2015-2-23 01:29
Thank you, this is great info
2015-2-22
GB44
Flight distance : 343848 ft
Sven,
What do you mean when you say Mod value
2015-2-24
T J Gilbert
Flight distance : 74659 ft
GB44 Posted at 2015-2-25 05:54
Sven,
This is from the P2 Assistant.
It sort of explains "Mod"...
2015-2-24
jimhare
Flight distance : 239035 ft
Is it okay to do an IMU calibration in the house on a flat surface or do you have to be outside with GPS reception?   I see a lot of people doing it indoors and only warning about doing a compass calibration outside.
Thoughts?
2015-2-24
