Would you fly with this propeller ?
1331 11 2017-2-24
seugnimod
Flight distance : 411073 ft
Portugal
Hi guys,
The title is self explanatory. Today I had a bit of a misunderstood with my mavic and it touched some branches while sliding sideways.
It hovers good.
Thanks !
2017-2-24
Ex Machina
Flight distance : 1806362 ft
I've seen Mavic torture videos where a prop has been clipped down as far as your crack and hovered fine, but should the tip fly off at speed it could take someone's eye out.
2017-2-24
Zorker
I personally wouldn't. I'd be concerned with the integrity at speed, both from a hazard to others as well as what might happen with control. For the low cost of a prop, I'd replace it. If you don't have any handy, i'd get in the habit of always keeping extras (doesn't help you now, but it's a good practice).
2017-2-24
seugnimod
Portugal
Thank you both. I have some spares of the fly more combo and I'll use them.
Both your points are valid and at the price of a new one, I shouldn't risk it.
Thanks !
2017-2-24
VAS67
Flight distance : 265984 ft
Never fly with damaged props.
Last year I was flying a model aircraft. On the first take off (grass field) I hit a bump and the prop briefly touched the ground. 0.5 seconds later the plane was airborne and I flew it around for about 15 mins, no problems at all and thought no more about it.
On second flight I took off and climbed out to about 100ft, heard a bang followed by a very bad sounding noise, I immediately throttled back to idle ( IC glow fuel  motor) and preceded to land. By the time I'd got to 20ft the tail of the model came off due to the massive vibration caused by a very unbalanced prop. Model crashed and unrepairable.  £1000 down the drain :-( Obviously until I retrieved the model I had no idea what went wrong. Whilst at 100ft the prop threw a blade, sheared right at the centre hub.  Not worth the risk throw all damaged props away and maybe even life them to say 20 or 30 hrs flying and then replace.
They are cheap enough vs a Mavic falling out the sky with hassle, possible libel suit and the expense of not doing so.
2017-2-24
superjet96
Flight distance : 142743 ft
The integrity is gone.  I would throw that straight in the trash and grab another.  That is what spares are for.
2017-2-24
AG0N-Gary
Flight distance : 700846 ft
Why risk it?  That thing could fly apart at any time.  Break it into pieces and toss it.
2017-2-24
FrequentFlyer
Not worth it to try, use your spares . And put in an order for more spares.
2017-2-24
devGOD
Flight distance : 200577 ft
$9 USD are you seriously asking if you should.... you spent over $1k USD on a drone spend the $9 on new blades
2017-2-24
CuaC
Flight distance : 369626 ft
I wouldn't. Why risking your drone on something that costs 9 bucks a pair?
2017-2-24
rick39
Flight distance : 164354 ft
Any imbalance or extra drag will put unwanted stress on the motor, causing premature wear. There are videos on the web of Phantoms and Mavics with half a prop cut off to show how well the  drone can still fly given all the stabilisation wizardry packed into these things. Beyond a test, it wont take long for that motor to over rev or suffer unnecessary wear.
2017-2-24
seugnimod
Portugal
devGOD Posted at 2017-2-24 16:00
Yes, I am seriously asking. I am not that cheap, but wanted to know if it would be risking or not. Now I know so.
And it's not $9 for me. For me is 9€, with the additional 28€ for shipping.
2017-2-27
