liningiv
Flight distance : 329409 ft
You could easily check the length of each spring it it's relaxed position, i.e. no props fitted, or easier with a prop just sitting on a spring. Maybe make a note and compare each week for your records. If it ever started to lose tension by the spring getting shorter then that is the time to replace.
I have just measured mine from the top of the prop to the bottom of the strobe along the motor vertical axis.
Relaxed is 62,58
Locked 59,88
Fully compressed 57,78
The springs are only being compressed by less than 5mm each time, so they will not be compressed beyond their yield point and enter plastic deformation.
And at one cycle per flight, if you remove the props each time you land, they will not fatigue in years or hundreds of years. Think of a ballpoint pen retraction mechanism. |
