Ex Machina
Flight distance : 1806362 ft
The quality of the video being transmitted is dependent upon several variables, most importantly being the quality of the video you are recording and/or streaming.
If your Hardware Decoding is disabled, do turn it on like PimpDawg recommends as that'll offload video decoding from your CPU to your phone's video processor, which can be much more efficient. I'm not sure this option is available on Android devices.
If you are using HD downlink video, then try switching from HD to Normal in your Image Transmission Settings, which requires less bandwidth on the downlink, and if you're viewing on a phone, anyway, I doubt you could tell any difference.
Lastly, there are some other options in the HD settings that let you examine your signal to see if there's any interference going on, and if there is, adjust your bandwidth/transmission quality settings to help compensate.
Hope this helps. |
