HWCM
Flight distance : 5484997 ft
mityadvet Posted at 2017-3-2 06:38
I'm also using an iPad mini without GPS, works fine. For RTH I think the Phantom records it's position, not the iPad. As for follow things get a bit tricky, I would recommend getting an iPad that has a Barometer and using the Autopilot App for best results.
Yes, RTH uses the GPS located inside the P3 itself. You do not need a ipad or tablet with GPS to fly the P3. But, you will not be ablr to use the follow funtion or to update your home point. Those two funtions require a device/tablet with built in GPS. This is because the tablet needs to know the GPS position to report back to the Phantom in the air.
Also, a barometer has nothing to do with the GPS in a tablet. I am not even sure tablets have a barometer.
Why do you recommend the autopilot app. What can it do that the DJI GO app does not. You are going to confuse the guy. |
