Rusty Iron
EastyT Posted at 2017-3-31 06:15
I have used the Yx 5 in 1 charger for Mavic with a 500W inverter and it works great. The advantage is that it will charge 3 Mavic batteries, the remote controller and your smartphone simultaneously. The peak draw I have measured at about 200W and it will charge all 5 devices in less than 1.5 hours. This device can be had for less than the advanced charging hub and will save quite a bit of charging time. The previous post is correct that there are some inefficiencies involved but only in the neighborhood of 15%. If you use the standard Mavic charging hub along with the DC car charger this would save about 1.5 hours of charge time and the hub does not charge the controller and phone at the same time. Also there have been reports that the Mavic DC car charger may not work unless the engine (alternator) is running in that it requires at least 13 volts or it will not work. This may be a good solution for you.
Thanks EastyT. By the looks of things, I shouldn't have too much trouble with a 1000 watt inverter and the Mavic charge hub, charging only the 3 batteries. I use an iPad 2 air for the RC, and I also use that while driving, as a 4WD navigator. So that is being charged continuously anyway. I have another spare USB port in the car, so I could charge the RC from that while driving between locations. |
