Mavic controller won't talk to DJI Go 4 app
1724 14 2017-4-8
RqbwEB1vl0m7
After Updating both Mavic and controller's firmware on DJI assistant for Mac, the controller will not talk to the app running on an iPhone 7s plus.
I can move the gimbal and turn on props with the controller, meaning that the controller and the Mavic are talking. However I cannot get past the welcome screen on the app and the status of the aircraft shows as disconnected.
I have been flying my Mavic frequently since December with no problem until now.    I have tried rebooting everything, uninstalling and installing the app several times and nothing seems to work.
can anybody help?
2017-4-8
quick_dry
Flight distance : 41526 ft
I had the same issue, I was plugged in via the bottom USB connector, then killed the app, connected via the side plug and restarted the app and after  few seconds it showed up connected. So basically, I have NFI what the actual issue was or how to fix it in a repeatable manner.
2017-4-8
lpoire
I have tried both side port and bottom USB connector, multiple cables and even what quick_dry did.
still not past the main screen.
2017-4-8
hungdang
Flight distance : 4931706 ft
1.Try to turn on the airplane mode
2. Format the micro SD card in the Mavic
3. Try to use the bottom usb port and make sure unplugged the side usb port
2017-4-8
AlainL
Flight distance : 2392 ft
Same issue with DJI GO 4 with Mavic with iPhone 6s. It has been working for weeks, and now, NO WAY, cannot connect anymore!!!
Controller "talks" to Mavic, but the app refuses to connect with the controller.
Tried to reboot iPhone,
Used bottom USB connection.
Used iPhone sync cable.
Deinstalled/Reinstalled the application.
Cleared to cache.
Disconnected/Connected the cable.
Restarted Controller, App and Mavic in different sequences.
Net-net, always the same, GO 4 does not connect with the controller and I'm stuck ... and frustrated.
Any clue?
Any help appreciated. I'm running short in options ...
2017-4-8
dronist
AlainL Posted at 2017-4-8 19:42
If you did not have any problem before, downgrade the AC / APP and see if it works again then you will know what causing the issue.
2017-4-8
lpoire Posted at 2017-4-8 08:19
When connecting your phone with RC via bottom USB port, did you remove the side usb cable?
Could you please clarify your current DJI GO 4 version?
Besides, since the issue only happen after the update, please try to downgrade the firmware to see if there's any change.
2017-4-8
Do you have another mobile device to test with?
Just want to rule out if it's the issue with RC itself.
2017-4-8
AlainL
Yes. Absolutely.
v4.0.6 (2855)
And how do I do that if the software does not connect?
Yes. Pristine. Installed DJI Go 4, plugged it in. Connect immediately, fly! No brainer.
Seems something is busted with the iPhone 6S installation, and even uninstalling and reinstalling does not fix it.
I could reset the phone of course, but I rather not do that because I will be in hell in many other fronts ...
2017-4-9
bamaflier
Flight distance : 170341 ft
I'm having the exact issue. It started before the newest firmware. It was connecting fine one day and a few days later it no longer connects to the app. I've tried three different devices (iPhone 7 plus, iPad mini 4, and iPad Pro)  I've tried multiple cables using the bottom and side connector and it's still a no go. I then updated both the AC and RC to the newest firmware and it still persists. The strange thing is I tried to revert the RC back to factory default and it will not do it. It says Error-unable to restore to factory default. I also erased the iPad mini 4 and restored as new, installed the go4 app and still no go. I plan to call DJI tomorrow. I've only had the Mavic around 4 weeks and now this issue.
2017-4-9
Oien
Norway
I have a similar issue. The iPhone (7) loses connection with the RC during flight. Mavic is connected to RC and I can fly it. App is open but it connects/disconnects randomly. Customer service said it is happening because I’m flying in a cold environment… I do not think that’s the issue, seeing that the connection is cabled.
Would be really happy if someone has any clue as to what is causing this…
2017-4-10
bamaflier
UPDATE: I tried an older Samsung Tab 4 and it connects but when I try my iPad Pro, iPhone 7 Plus, iPad mini 4, and even an older iPhone 5s it will not connect. The strange thing is my P4P will connect to all devices with no problem. DJI please help!!
2017-4-10
bamaflier
Finally spoke to DJI tech support after being on hold for over an hour and went through the troubleshooting and they told me to send in the controller.
2017-4-10
AlainL
bamaflier Posted at 2017-4-10 11:36
Believe it or not, but I upgraded my iOS 10.2.1 to the latest 10.3.1 recently prompted, and then after that everything works ...  Just that fixed it all in my case ... don't know what to say.
2017-4-11
AlainL
AlainL Posted at 2017-4-11 20:47
2017-4-11
