Nigel_
Flight distance : 388642 ft
It should descend at about 3.0 m/s in Auto landing, same as a P3, if you pull the throttle down then it may speed up a little, manual landing is similar.
In sport mode it should descend at around 4.0 m/s, including in Auto landing if you pull the throttle down - make sure you release the throttle before you hit the ground though!
It may be affected by wind, especially if it is gusty.
