RPM aerial
Flight distance : 38593 ft
Having the same problem with my slave remote. I think in my case the USB port of the remote has stopped working. I updated the drone with no problems using the SD card in the camera. Then I updated the Master controller with s USB stick. Again no problems. Then I went to do the Slave. Plugged the USB stick in (after deleting the txt file), and....nothing. The light is red, beeps twice and turns steady purple. It sits there for a few minutes then starts beeping continuously (lights stay purple). So I tried plugging the slave into the usb port on the Drone camera and following the directions in the video on the website. It looked like something was happening, however when all said and done I checked the txt file and it said the firmware was the same or older than that on the drone. It was like it did not even recognize the slave controller was plugged in.
So further testing I plugged the Ipad into the Master controller and started everything up. Ipad asks if you trust this computer, DJI Pilot app shows connected, and the Ipad shows it is charging. When I plug it into the slave, no request to trust this computer, App shows disconnected and it does not show charging. Repeated the same using different cable and my Iphone 6 and got the same results.
Anyone have anything else I could try or does this look pretty much like a faulty USB port? |
