tcrabtree
The RC and Pet versions of Marco Polo transceivers use the same circuit board and software but the RC version has a Li-Po battery that is 1/3 the capacity and a heat shrink covering instead of an ABS enclosure.
The pet version weighs 46 grams and the RC version only 12 grams. The actual "standby" time, that is the time from when you take of with a fully charged battery until the tag is unresponsive, is up to 30 days for the pet version and 10 days for the RC version. The longer times, 90 days for pet and 30 days for the RC version, are in the monitoring mode where the tag wakes up at a precisely controlled time to communicate with the locator once every 40 seconds. This is primarily used for monitoring wandering pets but could be useful for a UAV if you wanted a warning that your rig was moving on its own when it wasn't supposed to be.
I know it is counter intuitive that the standby time would be less than the seemingly more active monitoring mode but in standby the tag transceiver wakes once every 10 seconds and scans 50 frequencies to determine if a locator is searching for it. In monitoring mode the time and frequency for the communication is established and the tag wakes once every 40 seconds, quickly exchanges packets with the locator and goes back into sleep mode mode.
On the RF side it is the same power and sensitivity for both versions of the tag but the antenna gain is about 4 dB higher in the RC version. For RF propagation close to the ground 4 dB doesn't make a huge difference but it does help. Ironically, when the RF path conditions are really good and you are already getting miles of range the 4 dB improvement can be pretty noticeable but if you are slogging through the dense forest with the UAV upside down in a ditch and the range is already as bad as it's going to get - the extra 4 dB will get you only a few steps further.
One thing to keep in mind is that the Pet and RC versions of the tag can be mixed and matched on the locator up to a maximum of 3. So 2 dogs and a quad, a quad a plane and a cat, whatever combo you need is possible. |
