DroneFlying
Flight distance : 10774613 ft
I think I got it right.
Yes, you did. From what I'm seeing on Google Maps it looks like you had a clear -- and short -- path between the Mavic and controller, so that's good. I did notice, though, that the disconnects appeared to happen when you flew close to the ("Fredriksten Kro") inn.
This is just speculation, but I'd guess that there may be a strong signal generated from the inn that interfered with the connection between your aircraft and controller. If you're in a position to be able to recreate this problem then you might try flying near it again and see if the disconnects consistently occur when you're close to the building. If so, then I don't think you have anything to worry about, but if the disconnects just happen randomly and don't seem to correlate to specific locations then I'm not sure what to tell you except that you might have gotten a bad system. |
