Firmware update problems
1251 3 2015-3-9
rvarnell
I followed directions to the letter to update the firmware to 1.02.107 I got the beep...beep...beep...beep signal. After approximately 15 minutes, I got the
beep... ... beep signal indicating the update was complete. when I shut down the Inspire the .txt file read "canceled". when I booted up the inspire again, the pilot app said that I was running firmware 1.2.  However, I get no signal from the camera...red tab on Pilot app says no signal.
I reformatted the card and downloaded the firmware again, but now the Inspire thinks it has the correct firmware and will not reinstall.  Is there a way to rollback the firmware?
2015-3-9
timgoff
You need to update the RC with the same upgrade you used for the Inspire or they cannot talk to each other
2015-3-9
rfrye
Flight distance : 309606 ft
Did you update your remote also?
If the Inspire updates and tries to update again in the same session the results will be "cancel" because it has already updated it.
2015-3-9
rvarnell
rfrye Posted at 2015-3-10 00:46
If the Inspire updates and tries to update again in the same sessi ...
Thanks for the help!
2015-3-11
