Can't restore factory default from Assistant
2042 3 2017-5-31
suXvision
Flight distance : 38445 ft
Hello,
I'm tring to restore defaults factory setting form my ric mavic pro.
I've done easily for the Mavic Pro, but i can't do it for Ricevitor: i attach the prompt of dji assistant.
Another bad thing is that i've no list in firmware list.
How can i force the restore defaults factory ? Maybe without pass trought the dji assistant.
Thanks
failed
failed
no list
no list
2017-5-31
suXvision
Now I can see the list of firmware after some reboot, but the restore defaults always fail and the update stop at 72%
2017-5-31
AndyP.
Flight distance : 3738274 ft
are you using the usb cable that came with the UAS?
2017-6-4
fans3ce8009f
Poland
I have same issue + can't downgrade the firmware , after the update in may  V1.03.0800
It looks like there is no other firmware before  V1.03.0800 ( there only 2 positions   V1.03.0900 and  V1.03.0800 )
I have updated in MAY and I would like to go back to older firmware . Also I have tried with my iPAD - same thing , the oldest firmware is V1.03.0800
Apple doing the same thing with iOS if you upgraded to the latest iOS you can't go back
PLEASE HELP
2017-7-6
