!!!!!! A really good advice if you buy a DJI drone: For gods sake, do not crash it or do anything for which customer service is needed !!!!!
I was so unfortunate to crash my Mavic Pro drone into water after just 2.5 weeks in possession.
Luckily, I was able to get my hands on the drone, clean it with purified water and dry it on a bag of rice for a week. Unfortunately, the drone behaved strangely when turning it on afterwards and it would not fly. Therefore, I contacted the repair service from which I quickly got the shipment papers and I sent the drone away to be fixed. The ease of that part I was really impressed of!!
After a weeks time, I was told that the repair would be 860 euro (=970 USD) (case CAS-559366-N8Q4K5). I was really surpriced about the steep price, but thought that I would probably receive a new drone body as it was the only thing I sent to them. I kept the battery and controller. I payed - even though the drone made some mistakes in connection with the crash. I payed as I really did not want to fight with DJI over the payment for the repair as I wanted the drone back before a vacation I was leaving for a couple of weeks after.
When I received the drone, I noticed that the serial number was different than before and I was - for a short time - convinced that I had received a new drone. That was until I turned it on. When i turned it on, I noticed a really audible drdrdrdrdrdr sound from the acoustic sensors which can be heard in video 1. Furthermore, about 20 seconds after being turned on, the cooling fan started sounding like a space shuttle taking off (as you can hear in both videos) and the drone got really hot. Both of these observations was before I had even flown the drone.
Video 1
https://youtu.be/dqEhrzEFljs
Video 2
https://youtu.be/4SddZFukdPM
Stupid as I am, I decided to test the drones flying abilities despite something clearly indicating that something was not right. Let us just say that it did not go as intended as you can see on the picture below.
When the drone lifted off. It started flying backwards towards a wall without me touching any of the controls. A half a second before it hit the wall I touched the controls to try to avoid the crash, but it did not respond and then it was too late.
Well... Everything showed that I had received a defect drone. The drdrdrdrdr sound from the acoustic sensor, the INSANELY running cooling fan that started 20 seconds after turning the drone on, the extremely hot drone body after no time and of cause also that the drone flew directly into a wall right after taking off.
I therefore contacted the online chat customer service about all of the issues that had experienced. When finally getting a customer support guy on the line, I had to prove that I had installed the newest software before taking of, that I had not ignored some obvious errors and I had to re-calibrate the drone. After a half hour of different other tasks and sending him several screen shots from my phone on his command, he decided that he could not fix the issue via the chat (which I kinda hinted in the first part of our conversation).
I sent the drone in for repair (again) and then repair case CAS-626768-Z6K2D8 was started. I described all the issues I had noticed in the papers I put into the box together with the drone:
1. The drdrdrdrdr sound
2. The extreme heat the drone produced and the fan running like crazy after 20 seconds
3. That the drone flew directly into a wall at first takeoff.
After 20 days I received a message saying that I had to pay 126 euro (=142 USD) for new propellers and two drone arms with the following remark:
"No warranty, pilot fault. 1)Aircraft took off and worked at ATTI mode at t=64s, until t=68s when aircraft turned to work at OPTI mode. 2)Aircraft will drift at ATTI mode, because aircraft positioning function was not able to work at ATTI mode, it needs pilot to control the aircraft in every moment for maintaining the position. 3)Aircraft drifted at ATTI mode, then pilot pushed pitch stick backward, aircraft flew backward then crashed at t=69s near ground. The props are damaged. The front left and rear left motor arms are damaged."
First of all, the first Mavic Pro I had before the "repair" did not drift at all. It was rock-stable in the air and if it is supposed to drift like it did I will strongly advice you not to take of with a Mavic Pro near any kids or other living creatures and to keep a safety distance of more than 20m (60 feet) when taking off. And that is NOT reflected in all the videos put online by DJI. Furthermore, I am pretty sure that I pushed forward and not backward on the stick without anything happening, but I do not have access to that data, so DJI can write whatever they want to get more of my money.
Second of all, the other issues I had written to them about were not mentioned at all. I do not want a drone back with only new propellers and new arms. Something is clearly wrong with it and the issue was not that it was crashed into a wall. It was that somehting was clearly wrong from when I got it after the "repair" and the reason why it flew into a wall - not the damage after the impact.
The following customer "service":
I contacted the customer service through the message/mail function. I wrote something like I have just written above and we had a loooong conversation where after he promised me that they would made sure that the decision was re-evaluated. After some days, I checked the repair status and nothing had changed. It still said that I had to transfer money.
Then I wrote this to the same thread:
"Anyone there? Just checked the Repair Process Inquiry and nothing has changed. It still says: "The quotation has been sent to your mail box. Please check it. It will take 1 working day to confirm payment. Please wait patiently" The next step is not for me to pay. First, I really want an explanation for all of the issues that I had after the first repair that highly indicated that it was not a fully functional drone after the first expensive repair. The "new" issue is not that it flew into a wall and destroyed two arms and the propellars. The issue is that it made a strange sound and the cooling fan ran like crazy after no time (indicating that something was not right) and also that it was not stable at all when taking of - wherefore it ended up flying directly into a wall. Kind regards, Mikael"
And after one day I got this reply:
"Hi Mikael, Thank you for contacting DJI Technical Support. As I have checked on your case number, it is in quoted status. The quotation has been sent to your mail box as well as the analysis. Please check it. It will take 1 working day to confirm payment. Please bear with us and thank you for your patience with this. Best regards, Blessie C. DJI Technical Support"
I was stunned.. I had spent so much time describing the issue without anything happening - it was like everything I had described was just ignored. And now it seemed like the customer support had not even read the previous tread or my latest message at all. I wrote back and said that Blessie must have misunderstood my previous message and suggested that it was read again. Let us just say that I have not yet received a reply.
Tonight I decided to try the customer support chat function again.. After spending TWO HOURS of my friday evening describing the exact same issue again to a very unresponsive customer support person I got so tired of communicating to a wall. He said that he would make sure that the second repair case would get re-evaluated, but when I asked him to send a proof of that to my e-mail, he hesitated, but finally wrote that he could not do that right now, but after 24 hours. To be honest - after my other experiences - I really do not think that I will receive anything. And after that he asked me to give him a good review. I said I would do that when I receive his email. I have taken screenshots of our whole conversation if anyone needs a good laugh.
So status in this moment is:
Drone location: DJI repairshop
Costs (so far):
Mavic Pro fly more combo: 1200 euro (=$1350 USD)
First repair: 860 euro (=970 USD)
Total: 2060 euro (=$2320 USD)
Extra demanded by DJI: (which has my drone): 126 euro (=142 USD)
Do I have a functional drone: NO
Would I get a fully functional drone if I payed the extra 126 euro (=142 USD): NO
Fortunately, I have a good video of the first crash, the rescue mission, the issues I observed when receiving the drone from the first "repair" which will make a really good youtube video of this whole experience - including the customer "service" part. I look forward to finding out what the next step for DJI is - I really hope it is to actually provide some customer service for the first time in my case (maybe the second time as I got the currier label for the first shipment quickly "insert crazy laughing/ crying smiley").
