hallmark007
Flight distance : 9827923 ft
You can't switch to Atti mode with Mavic , if the area is bright as you said it open you should have no problem with gps, regarding steel the problem you might have with this is magnetic interference which would effect your compass so even if you had Atti mode you would still have a problem.
If I was you I would do a recon of the building to see if gps is good and if there are any noticeable effects from steel etc, just maybe 5 minute flight.
You could do a compass calibration in the building so you compass takes on the parameters of the area, but this could cause you more problems, a last resort maybe. |
