glataif
Hello,My name is George.
I own a Phantom 2 V. 2.0 and have had it for about three months.
Recently it was acting funny, for instance, not responding to the controller. I waited a day or so before powering it back on, I do have a full battery if you are wondering. It does not respond to my remote. I know it is connected because I can go into failsafe mode and the lights will flash yellow. Also, I can control my gimbal a little bit but it won't go up and down as much and makes funny noises when I do. Sometimes, I can get the motors running, usually I will arm it but nothing will happen, but I can't get enough power to lift off the ground. I have calibrated it, updated all the firmware.... I have done everything. I believe it could be a faulty transmitter or possibly a esc or electronic speed controll system. I have a warrenty but would not like to send it in just yet, just in case I can get it working before then. When I plugged it into a PC, earlier, this is the first time this has happened, I got an error 27 alert meaning GPS interference. PLEASE HELP!!!!!
So the problem is,
transmitter: does not startup motors...usually..... when it does there is little power to the motors.
Phantom: motors dont start
Gimbal (H3-3D) Does not respond to up and down.
