Nigel_
Flight distance : 388642 ft
Looks like it landed because the battery told it that there was no power left.
I guess it had a communication error talking to the battery. Was the battery securely clipped in?
Maybe the battery had a problem internally and reset or just sent the wrong data.
I've not seen that problem reported before.
I think that once it sees the battery is empty it should land as soon as possible even if power appears to come back, letting you fly it back home could be dangerous since it will fall out of the sky when the battery really is empty.
You should have still been able to adjust the landing position to make a safe landing by moving left-right-forward-backwards, and probably delay the landing with throttle up.
I would mark that battery as possibly faulty and be careful flying if using it again. If you see the problem again using the same battery then maybe get it replaced, if you get the problem again with a different battery then you know it is the aircraft. Make sure they are plugged in properly.
You could synchronise your flight logs in DJI Go and ask DJI support for advice, maybe they have seen the problem before, maybe they would replace the battery.
I think the aircraft is OK, the problem is probably in the battery.
Let us know what happens... |
