Fireman77
Flight distance : 39196 ft
Peru
w0lfy_ Posted at 2017-11-24 09:05
Ok, so did the calibration with the drone turned 90 degrees and it finished with success. However, two things are happening:
1. with the drone on level surface, the calibration gets stuck;
2. calibration finished or not, when the camera is facing forward, there is a buzz coming from the gimbal and the gimbal motors get quite warm. The buzz goes away if I lower the camera by few degrees.
Is there any chance that a certain firmware will kill a drone? my p4p+ was fine, it will be a year, with very little use, very few flights, it was damaged little by little with the updates that came out in the RC screen, I was forced to update, with the confidence that it is better and with the fear that if I do not update, everything will go to hell, this is what DJI has us used to. Now, when updating to an earlier version of the beta version, my problems, vibration and noise in the gimbal started, persistent. they told me to update the beta firmware and continue the problem, I can calibrate the gimbal but the vibrations and the noise in the gimbal continue and DJI only says, "send the unit, unit failed, failing factory" and I am thousands of kilometers of California. that's why I wonder, is it possible that a firmare will kill a drone? Listen to the engineers of DJI, go read this thread and solve our problems, for the love of God. |
