Drone fell for reasons unknown, please help
1348 16 2017-7-8
mityadvet
Flight distance : 492352 ft
Ukraine
Hey y'all,
my beloved P4P fell on the ground pretty hard and I can't understand why...
I have no experience reading flight logs, hoping someone here (from DJI Perhaps?) can help, here's the link: http://www.phantomhelp.com/LogViewer/GN1EDG9ZBYV4C6UQXVII/
The battery was still in the aircraft after the crash, so that couldn't be the reason...
Thanks in advance for the help!
2017-7-8
Mark The Droner
Flight distance : 2917 ft
The big glaring thing I see right away is you launched with less than a fully charged battery.  That has been known to drop ACs out of the sky without warning.  I can't say that's what caused your problem though.
2017-7-8
G Davidson
Flight distance : 263465 ft
Sorry to hear of your misfortune.
Looking at the logs, it seems that the drone was climbing and threw a propeller (or something damaged a prop in flight) after which the logs show the start of the fall.
2017-7-8
TacoRye
Flight distance : 174203 ft
At 4m into your flight, a motor error appeared.  Stating loose or missing prop.   Was it missing any props or flying erratically when it fell?
2017-7-8
Nigel_
Flight distance : 388642 ft
Doesn't look like it was your fault.
Things start to go wrong when the GPS receiver looses all the satellites and it drops into ATTI Course Lock mode, after that the compass and gyroscopes seem to go mad!
Not sure we can trust any of the data in the last part of the flight so it's hard to draw any conclusions.
Major malfunction - a warrantee issue...
2017-7-8
mityadvet
Ukraine
Thank you everybody for the help!!! Much appreciated!
Can someone from DJI take a look at this please and say if I can send it to the German DJI service as a warranty case? Never had any crashed and have no experience with things like these...
2017-7-8
mityadvet
Ukraine
TacoRye Posted at 2017-7-8 13:15
this is a trick question! how is a fall not erratical? a couple of props fell of and one broke into half after the crash
2017-7-8
hallmark007
Flight distance : 9827923 ft
mityadvet Posted at 2017-7-8 13:28
You will need to sync your flight to dji cloud in your app contact support@dji.com, and start a case.
If you want a mod to help you here . You could get your dat file download to Dropbox and PM  a mod here they will be able to get dji engineers to take a look for you below link will help.
https://datfile.net/DatCon/fieldsV3MP.html
2017-7-8
Nigel_
After the propeller went missing the aircraft managed to gain height!
I don't think we can trust the data.
2017-7-8
Nigel_
Get in touch with DJI support, several methods available, they will let you know where to send it: http://www.dji.com/support
If you synchronise your flight logs first in the Go 4 App then they will be able to take a look.
2017-7-8
mityadvet
Ukraine
thanks everybody!!
2017-7-10
Nigel_
What has DJI support said?  Is it being covered under warrantee?
2017-7-10
mityadvet
Ukraine
Nigel_ Posted at 2017-7-10 02:36
they told to to send it in for future diagnostics, syncing my flights in the app didn't matter...
2017-7-12
mityadvet
Small update on the subject: after weeks of waiting to hear back what actually happened DJI sent me a repair invoice for over 600,- Eur to cover the damage. Since I'm pretty sure I didn't do anything wrong or didn't hit anything here's my question: is there any chance DJI can cover this under warranty?
2017-9-2
Nigel_
mityadvet Posted at 2017-9-2 04:16
What reason have they given for the crash?
I suggest you get one of the moderators on here to organise a review, a quick look at the data might indicate it being your fault but I think a decent look shows that there was something wrong with the aircraft.
2017-9-2
mityadvet
Nigel_ Posted at 2017-9-2 05:11
Thanks for the reply, Nigel!
Here what was written in the invoice "no Warranty - Flight-Logs gelesen: 1.The aircraft was controlled by pilot in GPS-CL mode. 2.t=392s,h=7m,d=123m,aircraft crashed.Before the crash pilot was pushing 100% pitch stick backward and yaw stick to the left,100% throttle stick upward."
2017-9-2
mityadvet
Oh yeah, any tips on how to get any of the moderators attention here?
2017-9-3
