Mabou2
Flight distance : 811257 ft
Same problem here with iPad Mini 2. Rarely had this problem before todays update.
I've been doing quite a bit of experimenting with this issue today and have found some repeatable results.
1) The problem does not appear when cold booting everything. The video transmission is fine, even when flying quite a distance.
2) After a few minutes, the problem appears and gets worse minute by minute. This indicates to me that it is heat related, probably the heat of the iPad. Take a break to cool things off, the video transmission problem goes away, until things heat up again.
3) All things being equal, this problem only shows itself on the iPad Mini 2, not on my iPhone 7 Plus.
4) Although this is just a gut reaction (with no evidence)... as soon as I started recording video (rather than just watching on the iPad), the image started hesitating, then soon after started pausing with green and black bars. I'm thinking that the combination of processing the typical bandwidth of flying, coupled along with recording video and audio to the iPad Mini, might be more than the thing can handle. The iPad mini 2 is getting long in tooth, and the new DJIGo4 might not be the most frugally scripted app in the world. |
