Andrew_tw
Flight distance : 1157464 ft
kamil111444 Posted at 2018-4-18 12:55
I connect Mavic Air by cable which came together in Fly More Combo Box and than I use Apple usb to lighting OTG cable. I can import photos to mine camera roll this way, but not directly to DJI GO 4 app.
Thanks, I'll check this reader !
Thanks for the clarify.
WIthin DJI GO App, there are 4 tap in the bottom.
Under the 2nd tap (Editor), you should see right on the top, Album and Create. Plz click on Album.
Then you should see an icon on the top left corner, where you can import media files from
(1) On-board SD
(2) Local Photos
(3) Local Videos
(4) DJI Display
Once you imported, you can switch to the Create tab, and edit your video.
Please note, once you finished edit all your videos, DJI GO App can only allow your export your final work in 1080P. not 2K, not 4K
Personally i use another great app call "LumaFusion" on my iPad Pro.
It's got almost everything you need and the editing speed is faster than my 2014 MBP.
Best part is, i can export to my camera roll or Youtube in 4K and have many FPS option to choose from.
Hope this helps. |
