Range Question
1894 13 2017-7-29
StarFishUK
Flight distance : 54970 ft
This isn't a complaint - I want to say from the start I love my DJI Spark.
I live in the UK and fly with an OTG cable with my phone in airplane mode. My phone is a Samsung Galaxy S8 and as far as I know there is no way to stop it connecting to the Spark at 5.8Ghz. Typically I can get the Spark about 100 meters away before I start to get video signal warning messages. This is a LONG way short of the 2Km advertised and while I love the Spark this aspect of it is a big disappointment.
My questions are....
Is this going to improve with future firmware?
Is this a result of UK regulations?
Are the regulations likely to change?
If they do will the Spark be updated by firmware to give a better range?
Do other DJI drones have the same problem?
Essentially - is there any hope for the future or am I stuck with 100 meter range?
2017-7-29
hallmark007
Flight distance : 9827923 ft
In Europe CE you are confined to 500 metres, this won't change with firmware update, you need to be using RC to get this distance and you would be better switching to 2.4ghz.
2017-7-29
fans1e71c6dd
Flight distance : 1742 ft
Your getting about the max with a phone really.you need to purchase the rc to get any further!
2017-7-29
StarFishUK
hallmark007 Posted at 2017-7-29 09:00
Thanks for your response. I am using the RC and as far as I know, there is no way to switch to 2.4 - it just keeps switching back.
Do other DJI drones have the same restrictions? If I bought a Mavic would I have the same problem??
2017-7-29
Dirk52
Flight distance : 232995 ft
StarFishUK Posted at 2017-7-29 09:08
The Mavic uses OccuSync. You will get much more distance with the rc!
2017-7-29
hallmark007
Ok you need to start up your aircraft, go to signal option, you will have option of 2.4 or 5.8 , click on 2.4ghz then scroll down you will see first graph with numbers and red and green lines underneath that there is a slide with numbers (channels) select a channel preferably a green one with the smallest green line once you have selected channel wifi will will switch off then back on you will then be connected to 2.4 ghz.
I don't know why they have it set up this way it's a bit of a pain but that's what you have to do to get 2.4 ghz.
2017-7-29
StarFishUK
hallmark007 Posted at 2017-7-29 09:18
This is really helpful! Thank you!
2017-7-29
hallmark007
Max distance with Mavic CE 4km 2.5 miles, it operates on 2.4ghz.
2017-7-29
Lian82
Flight distance : 796775 ft
But if there is a channel without green and red? is better?
Does it mean no interference right?
2017-7-29
hallmark007
Lian82 Posted at 2017-7-29 09:23
I think it channel hops any way picking the best signal automatically.
2017-7-29
CoreyB10
Flight distance : 1665023 ft
Hemmed in with the phone Starfish. I'm in the UK, Fly-More combo and no issues at all with distance or altitude. Like most people complaining of this - Take the plunge and get the controller. It also states the ranges for when using the phone and the controller before you buy. I get it that people will not see this but its the controller is the only option for if you want to take her out further and higher my friend.
2017-7-29
hallmark007
CoreyB10 Posted at 2017-7-29 23:45
He is using RC.
2017-7-30
paulhummerman
Flight distance : 114915 ft
the smallest green line?  these lines measure the strength of the background 'noise' wifi signals,  and one trying to minimize background?
i've been choosing the longest green line!
2017-7-31
StarFishUK
paulhummerman Posted at 2017-7-31 18:01
I feel your pain. I've been unsure what to choose, but I noticed that the more remote the location I am in the shorter the green lines - therefore I assume shorter lines indicate less interference. Where I live is quite rural so it's not unusual to see all of them completely flat and green.
2017-7-31
