DJI mavic pro battery
1834 12 2017-8-1
djiuser_7LYc5JM
hello, Im not sure if theres a thread about this but my dji mavic pro batter just out of no where stop charging and it wont power on. when i put it on my charging hub it'll turn green then immediatly turn red. when i press the button to turn it on i get no green light indication. not sure if this had happen to anyone else. please help
2017-8-1
DroneVibes
Flight distance : 38173 ft
Hi. Sorry to hear of the battery problem.  Do other batteries charge ok on the charging hub?  Did you try to charge it with the connector only and not use the 4 way hub just to rule out hub issue?
Also, did this battery endure any damage say in a crash or get water in it or on it?  Extreme heat at any point?
It sounds like the battery is now defective but that could just be product defect or caused by some of the above mentioned items.   If it is defective could be the charging circuitry or one or more cells.
2017-8-1
Lucas775
Flight distance : 50642090 ft
Does it have enough power to power up the Mavic and check the voltage on each cells?
2017-8-1
dronist
Batteries have 6 month warranty with less than 200 flights. Send it back dude!
2017-8-1
DJI Diana
Flight distance : 2408 ft
Have you tried to charge it via the charger directly? If yes, how is it going? Batteries have 6 Months warranty with Charge Cycle less than 200 Times, please contact the Support to start a case if the battery is faulty and still in warranty. http://www.dji.com/support
2017-8-1
dRT_dIRTY
DroneVibes Posted at 2017-8-1 16:32
the battery did charge up before on the hub i was using it just fine and it drained out so i slapped it on the hub with the other ones and when i grabbed to use it wouldnt power on at all, there was no damage i just got it less then a week ago.
2017-8-2
dRT_dIRTY
Lucas775 Posted at 2017-8-1 18:08
it doesnt turn on at all so i cant even tell if it has power or not
2017-8-2
dRT_dIRTY
dronist Posted at 2017-8-1 18:13
i called them yesterday and they made me a claim and sent me an email but it doesnt say if they were going to spend me a shipping lable or anything.
2017-8-2
dRT_dIRTY
DJI Diana Posted at 2017-8-1 18:42
I did contact them yesterday, so fair i havent gotten any instructions on what to do next regarding warranty.
2017-8-2
dRT_dIRTY
Thank you for all the comments and help! Much appreciated, Im very new to this forum. thank you for the help and gestures!
2017-8-2
dronist
dRT_dIRTY Posted at 2017-8-2 13:31
Keep up with DJI Diana and she will help you out. good luck dude!
2017-8-2
DJI Diana
dRT_dIRTY Posted at 2017-8-2 13:29
Have you got a case number from the Support? If yes, please provide me with your case number so I can check it. If not, please refer to the link below, see if you can submit an online repair request. https://repair.dji.com/en/SelfRepair/Area
2017-8-3
dRT_dIRTY
dronist Posted at 2017-8-2 17:25
Thank you so much!
2017-8-3
