Maybe firmware problems
830 7 2017-8-10
fans64143ce6
Maybe this has been covered.  I think I am having firmware problem, my p3s will not hover in one spot, it moves side to side and front to back. Also my camera is slightly tilted to the left. Could this be a fw problem?  I have calibrated the cumbal and the imu. Still flied erratic. The dji go apps says I have the latest update.  Also I have no map.
2017-8-10
UpNorth
Flight distance : 311089 ft
hmmmm..... tricky issue.  first thought, has home point been set? Are all devices 100% charged. Most of all has aircraft and controller been through all calibrations?
2017-8-10
fans64143ce6
Home point set, everything charged and all calibrations done, rc and ac.
2017-8-10
fans64143ce6
Also noticed today when I landed the quad, I let it run idle a few seconds and the quad tried to roll over to the left.
2017-8-10
Cetacean
Flight distance : 2528264 ft
fans64143ce6 Posted at 2017-8-10 19:21
Aloha fans64,
     Have you checked for magnetic interference?  Also, is there any interference from running fans or electrical wires?  What type of environment are you flying in?
Aloha and Drone On!
2017-8-11
DJI Susan
I would recommend you calibrate RC sticks first to check whether it helps.
2017-8-12
fans64143ce6
I've already calibrated everything that can be calibrated, and yes, I calibrated the RC first Susan,
2017-8-12
DJI Susan
fans64143ce6 Posted at 2017-8-12 10:18
Is the RC calibration successful or not? If yes, please PM me your DJI account and upload the flight record, I'd like to look into it.
2017-8-12
