Aardvark
Flight distance : 384432 ft
Try another method, it may work:-
With RC and display connected (aircraft off), and display has a good wifi connection to internet. Run DJI Go 4 and 'enter device'. Open the 'aircraft status' screen by tapping the screen at top edge where it says 'disconnected'. The top line 'Overall Status' should show if update required (this may take a few seconds to appear). If it does then tap on that and it should take you through the process to update RC. That may make the difference to your display.
Or you could try :-
Connect display device (with good wifi connection) to RC and power both up (aircraft off).
Run DJI Go, on initial screen (where it displays aircraft type etc) at top right hand corner you will see three lines if DJI Go 4. Hold your finger on that for about 5-8 seconds and release. You should now see a black screen appear with an option to roll back RC firmware (you may have to sellect V1.3.1000 in the roll down menu). Make sure RC is well charged, takes about 5 minutes or so. Power down when complete. Restart all and check all working, you may need to relink RC to aircraft. |
