QuickShot on objects (not people)
5026 17 2017-8-23
fans6ac931b5
Flight distance : 45217 ft
Good Evening
Is there any way to do quickshot around an object instead of a person?
I was trying the other day to select a castle tower , i wanted to select an object and let it turn around it keeping camera locked on it (spiral) but it wont allow me as it says object unrogonised.
whats the best way to do this to turn around an object and film it from all angles automatically.
similar to point of interest on the parrot drones.
thanks
Eden
2017-8-23
LouisP
Flight distance : 41952 ft
I tried that for the first time today and it worked for me...
I set it for auto track then drew a box around a stationary object and hit GO...
Then I could move the drone side to side... forward and back.. and up or down and the camera stayed pointed at the tracked object.
This is a great feature for filming.
2017-8-23
scottychop1
Flight distance : 2513 ft
I too, would love for this to be possible.  I don't really like to be in front of a camera...
2017-8-23
fans6ac931b5
LouisP Posted at 2017-8-23 17:30
its too manual
I want it to be more automatic .
can I draw a path around the castle and tell it to turn around it and focus camera on the object? then press GO?
2017-8-23
Sparkylicious
Flight distance : 72306 ft
Yes it works.
2017-8-23
Convert
Flight distance : 6129 ft
I suspect the issue with your castle tower is that it is attached to a castle and not visually dissimilar enough to its surroundings. That cube above works as it contrasts well against the green grass.
2017-8-23
Dirk52
Flight distance : 232995 ft
Normally you would use the Point of Interesst function. Unfortunately the spark doesn't support it. So you have to do it with either with active track or quickshot. You must draw a rectangle around the object. Clicking on it only works with known objects. (Car, People, bycycle..)
2017-8-23
Montfrooij
Flight distance : 2560453 ft
What about a moving object like a train or a car?
2017-8-23
moh_rafiudeen
Flight distance : 328957 ft
Montfrooij Posted at 2017-8-23 22:24
I tried tracking a slow moving  car.. I kept spark 90 degree to car and it did well..
2017-8-23
fansf0280671
Flight distance : 123064 ft
Works great in active track, you can adjust the speed of the circle and manually fly further away and higher and it will remain locked on the stationary object - excellent for smooth POI types filming.
2017-8-23
Sparkylicious
fansf0280671 Posted at 2017-8-23 23:13
Yes , i agree. It really works
2017-8-23
Montfrooij
moh_rafiudeen Posted at 2017-8-23 22:30
Thanks. Do you have some video online from that?
2017-8-23
Montfrooij
Thanks a lot. Do you have a link to a video online?
2017-8-23
fans6ac931b5
Sparkylicious Posted at 2017-8-23 21:34
Yes it works.
https://www.youtube.com/watch?v=l7vxjoEFI2c
how did you get it to work.
mine keeps saying could not recognize object
2017-8-24
Sparky_17
Flight distance : 62349 ft
The Active Track works well both when setting it up in the App or when I gesture mode (no App connected).
2017-8-24
Sparkylicious
fans6ac931b5 Posted at 2017-8-24 07:27
The trick is do the shot when the contrast of the object is greater than its background. So try it on different time of day.
2017-8-24
Ace Flysome
Flight distance : 37671 ft
try selecting only part of the tower. I tried doing rocket on my car but it didn't recognize it until I selected a smaller part of the car or going further away to start so the car itself was smaller.
2017-8-24
DJI Thor
Flight distance : 13602 ft
It will work once the subject can be recognized.
2017-8-25
