longest distance for image transmission
1991 11 2017-8-26
ilsaarin
Flight distance : 52339 ft
Finland
Phantom 4 pro is advertised with huge range, around 7 kilometres. Today, the flying distance was less than 1 kilometer above the lake. Image transmission was unusable. Drone activated automatic return-to-home function twice. Live streaming was crap. Is it so that european models don't have such range as Phantoms sold somewhere else in the world? The situation has gone worse with every firmware update. Why it is not possibe to set transmission frequency setting to custom? I can only keep it in Auto. I can chage the frequency, though.
This investment has becoming more unusable after every update.
2017-8-26
15matjan
Flight distance : 1158258 ft
I own a P4P+ and after last firmware is WORSE, WORSE, WORSE than my previous P3A. With the previous one I was able to fly 2- 2,5 km far in the same area, now with the P4P+ I can't fly more than 1 - 1,5km.
And it is not a NFZ nor close to any.
I guess DJI knows why and I think nobody expects improvements in the future. It has turned in a marketing issue & false publicity and they are foolishing the customers...
2017-8-26
Eric13
Flight distance : 13982031 ft
The P4P remote knows its position and will automatically adjust signal strength based on local laws.
If you take your drone to the US you have much more range.
Thus it makes no sense to buy a drone in the US hoping you can fly it further in Europe.
In the P4P specs it says:
Max Transmission Distance 2.400 - 2.483 GHz (Unobstructed, free of interference)
FCC: 4.3 mi (7 km)
CE: 2.2 mi (3.5 km)
The furthest home distance I ever made in CE region was 2,6km.
Countryside, unobstructed view..
There is a workaround to get to custom settings:
Set the region on your device to US. I did so on my iPad Mini 4 and it works.
Under HD I tried all kind of transfer settings, tried the channels that looked best but live streaming didn't get any better.
2017-8-26
G_Sig
Flight distance : 9109311 ft
Iceland
15matjan Posted at 2017-8-26 12:29
It has been like this for long time. We end up with long selfie stick. I have P3S  on old Fw and it still goes 1000m to 1500m and will newer bee updated.
2017-8-26
ALABAMA
Flight distance : 10442687 ft
G_Sig Posted at 2017-8-26 12:56
LOL   "long selfie stick"
2017-8-26
ilsaarin
Finland
Eric13 Posted at 2017-8-26 12:49
Any tips how to do this? I mean region change.
2017-8-27
dancopter
Flight distance : 17901030 ft
United Arab Emirates
I got 5k on the latest firmware (FCC I think):
2017-8-27
Xian Onemanshow
Flight distance : 5384334 ft
Great , 5173m for me today  ( 12kms roundtrip ) had to turn around to make sure  i have enough battery .
2017-8-27
Eric13
ilsaarin Posted at 2017-8-27 00:40
I don't know on Android. I think you have to create a new account with Google for that matter and define your region being USA. I'm sure someone here will know.
On an iPad or iPhone you go to Settings > General > Language & Region...
2017-8-27
ilsaarin
Finland
Thanks. I have done that. Have to make a test tomorrow if the weather is good enough.
2017-8-27
Eric13
ilsaarin Posted at 2017-8-27 13:09
Remember when you are on "Custom":
The channel you select won't be changed if it gets weak.
I think on AUTO the channel is being dynamically chosen during operation according to strongest signal.
In Custom it will hold onto the preset channel.
Good luck. It didn't make any changes for me, no matter if I chose 2.4 or 5.8 GHz.
2017-8-27
DJI Susan
I would recommend you to check the channels of image transmission settings when the reminder pops up.
2017-8-28
