M1dn1ght N1nj4
Flight distance : 11522 ft
OK, so after playing around with the Spark for a while, I've come to think about a couple things.
First, could the camera actually take 1080@60fps? I mean the hardware side. 60fps might be a bit much to stream over wifi back to the phone, BUT, what if it could be enabled by the user, ONLY if there was a microSD card inserted in the Spark? Higher data speed as it's a direct write to the card, and wouldn't take up a ton of WiFi bandwidth to the phone. It just feels like the camera is lacking way behind even most old cellphones now.
Next, with the upcoming release of the Mavic Pro Platinum, I was looking at the shape and design of the new props. I wonder if it would be possible to make props for the Spark with a similar design, cutting down on noise, and getting a bit more "bite" out of the air.
Also, and this one might just be a personal preference, but what about an option in the GO4 app, that would allow the user to "disable" the gimbal during flight, so a solid gimbal protector could be installed. This would assume that the user wants to only fly it, and isn't interested in the FPV portion (for whatever personal reason). Would also really help if there were a crash, as the gimbal would be protected by the plastic shield. Just a thought. Probably not worth it, but I'm just spewing out my thoughts here.
Just wanted to speak what was on my mind. Afterall, that's what the forums are for!
