Do I dare upgrade to .1000?
1528 26 2017-9-4
Håkan K
Flight distance : 262946 ft
I'm new to Mavic but have experience of Phantom and Inspire. The plain and simple question I have. Are there any major flaws in the .1000 FW upgrade or can I safely upgrade?
Thanks for any input.
2017-9-4
Flybee
Flight distance : 2203983 ft
Sweden
It is different opinions about that some have gotten it to work really well and other not. So if you have a "stable" performance now I would say Wait. What version are you on now?
This is my situation at the moment.
https://forum.dji.com/forum.php? ... mp;page=1#pid942537
2017-9-4
TroutboyNZ
Flight distance : 1726486 ft
New Zealand
1000 working fine for me, no issues at all. The guys I work with are also running it no problems, only thing I haven't tested in depth is range, had 900 out to 4.1km no worries so hopefully 1000 still the same...
2017-9-4
alex_markov
Flight distance : 39244380 ft
Bulgaria
I would not suggest catching this one-way train stay on Your current setup if there is no problems present I personally had many problems with .1000 and DJI will not let You go back
2017-9-4
Dirk52
Flight distance : 232995 ft
alex_markov Posted at 2017-9-4 23:14
Dji will not, but others do
2017-9-4
Håkan K
Ok .. .. The one and only reason i was thinking of updating was I got a "IMU calibration needed" (or similar) just after take off the other day. I landed and the message got away. Then up agaian without any issues or warnings. Checking the IMU calibration afterwards showed normal figures ..
2017-9-4
Flybee
Sweden
Håkan K Posted at 2017-9-4 23:47
IMU calibration is not any reason for updating, stay where you are.
2017-9-5
Håkan K
Flybee Posted at 2017-9-5 00:36
Of course not. But a false warning might be. However, read about your obstacles and stay put for now.
2017-9-5
Fingers
Flight distance : 1365676 ft
I'm surprised that users are reporting 'no issues' DJI Support have confirmed that there is a compatability issue between the new firmware and DJI Assistant 2 (A new release of DJI Assistant 2 is anticipated).  So if you upgrade you wont be able to access Flight Data from the Mavic's SD 'glued in' SD card.
I've not seen any other confirmed issues. I personally haven't seen any Mavic, controller or image issues after  upgraading; only the issue mentioned above.
2017-9-5
Flybee
Sweden
Håkan K Posted at 2017-9-5 22:00
It's most likely fixed think it is the app but need to do more testing, before i write it of.
2017-9-6
Dread-Pirate-Ro
Flight distance : 2169731 ft
Flybee Posted at 2017-9-6 01:39
I have heard some horror stories about 1000 somebody on here messed his ac and rc up! Im on 900 and staying put. Ive heard 700 is really good aswell if you ever want to hack the firmware. That i will not do!
2017-9-6
fansa7dc5944
Flight distance : 50988 ft
Thailand
Read the release note. No benefit to update.
2017-9-6
WolfgangStiller
Flight distance : 599416 ft
I updated to .1000 with no issues. Works fine and I got benefits with the goggles.
2017-9-6
Mari
Flight distance : 1308780 ft
Fingers Posted at 2017-9-5 22:27
... not been able to access flight data that is on the internal SD-card will not be an issue for most of us. I really don't care if I can access flight data or not, I bought my MP to fly and have fun....
I can tell you that, without doubt, I have lots of fun when flying the MP on FW .1000.
2017-9-6
Fingers
Mari Posted at 2017-9-6 08:55
This is all about having fun, why else would we purchase a Mavic.  However, don't under-estimate the utility value of the Flight Records in having fun though. It provides rapid self diagnosis of problems as you can relate it to other factors being inputted into the Mavic.....good examples would be barometer problems or vision sensors.
2017-9-6
$gambino$
Flight distance : 1563980 ft
Fingers thats if u have problems or are having a problem. Is there something wrong that you need the flight records all the time?
2017-9-6
Fingers
$gambino$ Posted at 2017-9-6 12:18
No, of course you don't need access to them all the time. You access them when you need to. Though they are great for confirming the performance of the Mavic; new batteries for example, or checking what triggered a 'brake' flag.  I got a new battery quickly exchanged because of a problem spotted in Flight Data, this could have resulted in a loss of Mavic if I'd carried on using it.
I don't check my bank account transactions or phone calls all the time; but I would be pretty annoyed if I suddenly became unable to do so.
2017-9-6
$gambino$
I guess to each there own.... I could see the only time that you would need it as if you had to send the Drone in other than that you could View most of the information on the go 4 app like battery stats etc.  /See why its braking
2017-9-6
$gambino$
What was the battery that you figured out in the flight data? Serious question. Because i know the go 4 app will alert u if there is a battery error it will also tell you the votes of each cell.  And total mah vs used mah . So if you see something is off it is right there
2017-9-6
$gambino$
Volts*......
2017-9-6
Mari
There is an "edit"-button on the bottom of your message
DJI knows we can't access the flight data via DJI Assistant 2 now, they also said that there will be an update of DJI Assistant 2 soon... we just have to wait in that and in de mean time make some fun by flying the MP...
2017-9-6
Fingers
It was very intermittant battery error on the app, but when looking at flight data, you could see irratic batt volts and a constant battery temp (which was odd), local supplier confirmed that battery temp wasn't being correctly monitored.  Local supplier exchanged it.  I fly with multiple batteries and every so often I like to overlay battery data using the data viewer, it is easy to spot which battery is performing best / worst.  I've found that complete discharge / recharge does help.  As mentioned on other threads / forums.
I've also noticed a couple of my favourite flying spots are subject to weaker RC Signal / GPS Signal.  I still fly there though!
I find it a useful tool, and I learn a lot from understanding the data.
2017-9-6
GovGeek
Flight distance : 88980 ft
I was trying to do some "exploring" with parameters in the  Assistant last night. But before that, I was able to use Assistant normally and update the firmware to 1000. Then I tried exploring again and I just get spinning icon on the left pane with a "denied" logo when hovering over the options menu on the far left. I was not able to redownload flight data after the upgrade.
2017-9-6
Sprtbkrydr
Flight distance : 3777011 ft
Put it on .0700 and be done with it.
2017-9-6
$gambino$
Yup on .700 too and i know mari i cannot find this edit button tho on s8+ and even when i put into desktop mode it stays on mobile version....dang Samsung internet
2017-9-6
Flybee
History shows that it is like roulette to upgrade, not so much about the software I think it's more about what you aircraft is in for status. I think it's random how you are affected.
Is this thing affecting the flight conditions? Not to my knowledge so I have no interest at the moment that DJI assistant is working to expactions, It's not good of course but this is most like an area where DJI have to improve. IE sync releases.
Or the don't want us to be able to read the logs.
Happy flying
2017-9-6
Flybee
Dread-Pirate-Ro Posted at 2017-9-6 02:18
I'm glad that you have a stable version that is working for you.
No, I will not do that either I guess. To little knowledge yet.
Happy flying
2017-9-6
