Connecting iPhone 7 to RC via cable
1277 4 2017-9-9
HaniLondon
Flight distance : 223048 ft
hi,
I would like to hear from others regarding their experience in connecting their spark to the RC via cable. My connection worked but kept on getting disconnected after a minute or so. Had to manual land th drone to re-establish the connection. I gave up after a while. I am using a connector from Marlin usb 2.0 on the go which connects to the RC and provides a usb connector to connect the original iPhone 7 charging cable.
Please let me know your experience. If it has worked, can you please let me know if you did anything in the app and what cable / peripheral you have used
2017-9-9
Charles Adams
Flight distance : 3821312 ft
I've had success connecting to RC via OTG cable, but I have found a few interesting things.
1)  Cables aren't very rugged.  My first OTG cable kind of fell apart after a few weeks of use.  I noticed that the connection from phone to RC was getting very unreliable via (this) OTG, and I spent hours trying to figure out why by experimenting with startup order and connection order.  I FINALLY examined the cable and found that the female housing had come loose, and that I needed a new cable.
2)  The USB cables I've used have likewise not lasted very long.  My favorite cable (it's green and matches my spark, what can I say?) stopped working for connection, and I had to go to another cable.
It seems to me that using these cables in the field is harder on them than their probable intended use, and now when I have OTG connection issues the very first thing I check is the integrity of the cables.  I carry a spare usb cable and spare otg cable.
2017-9-9
DJI Diana
Flight distance : 2408 ft
It is not recommended to use the OTG cable since it hasn't been fully tested. Have you tried the WiFi, does it have the same issue?
2017-9-10
HaniLondon
Thank you both for your replies. Wifi  works perfectly well.
The Marlin OTG cable with apply power usb don't  not always work. Yesterday I noticed that the iPhone went to charge mode when connected to the RC.
2017-9-10
DJI Susan
HaniLondon Posted at 2017-9-10 02:41
Thanks for clarification. We can not ensure the performance when connected with OTG. Should you have any further questions, please contact us.
2017-9-11
