Can the Gimbal point up?
3670 13 2017-9-9
willoneal
Is there any way to make the gimbal point up just a little bit? On the screen, there is the gimbal position indicator, and it extends above horizontal, but I can't move the camera past horizontal.
Is it possible to look up a little? Is this my issue alone or is it not allowed at all?
2017-9-9
ps01
Flight distance : 3579409 ft
Yes you can, but only in tripod mode.
2017-9-9
DJI Diana
Flight distance : 2408 ft
It can't look up, as you can see the specs of the Spark.
Controllable Range
Pitch: -85° to 0°
2017-9-9
Wachtberger
Flight distance : 261509 ft
It can look up very well  for panorama pictures. But this happens through the software, you can't do it manually. Nevertheless this is the evidence that technically the gimbal is not limited to 0°
2017-9-10
S-e-ven
Flight distance : 5922034 ft
Thailand
Spark can  "0°" in full speed sports mode.
Which is a lot more + as 0° in reality, isn't it?
It is doing +° in Pano modes.
So DJI only needs to allow the usage for video and photomode.
Maybe in tripodmode or slow flights with obstacle avoidance on or such.
DJI, let the pilot decide, if he wanna risk propellers in the piture!
Please ;-)
And being on it:
How about that we can do Panos with setting the  -° angle for the first center-picture by ourselfs?
I would love to have some Panos with less sky, sometimes, and more foreground/bottom.
But without having to fly the Spark in usual "Smartphone" heights and in closer distances!
It still should be a Pano, not a closeup
2017-9-10
ps01
Seriously, I am using an iPad mini connected via USB ( or wifi ) to the remote and in tripod mode I can lookup up about 10 to 15 degrees ( see pics below )
I also work with my android phone connected to the remote. Note that I did not try without the remote.
horizontal
horizontal
up
up
2017-9-10
Aeromirage
Flight distance : 1778045 ft
You can add 10 degrees by adjusting gimbal pitch in settings.
2017-9-10
SeanGillian
There is a slight adjustment you can make in the DJI Go app camera setting, turn on Spark with camera facing you, connect to your app, and go into camera setting and adjust gimbal....you can see it moving up and down to your preference setting
2017-9-10
Montfrooij
Flight distance : 2560453 ft
Interesting feature
2017-9-10
willoneal
I see. Thank you.
2017-9-10
Aeromirage
Just confirmed that it will point up when in tripod mode.
Thanks ps01!
2017-9-10
Lucas775
Flight distance : 50642090 ft
Hopefully DJI can add this feature to the next FW update, If the mavic can do it i'm sure it's possible for the spark also.
2017-9-10
MauiMacMan
Flight distance : 673698 ft
I’d like to know that also?
2020-1-3
S-e-ven
Thailand
MauiMacMan Posted at 1-3 06:47
It can in tripod mode!
2020-1-3
