Spark and controller connection issues
2615 15 2017-9-10
aguilera_br
Flight distance : 18507 ft
Brazil
Guys
My spark and controller is taking a lot of time to connect when I turn it by the first time, controller's wifi is not broadcasting SSID as well. But on the second time I turn on the controller it seems to work well!
Please check video attached.
2017-9-10
jksphoto
Flight distance : 114121 ft
Have you got your wifi and bluetooth switched on, on your MacBook ? That will probably not be helping with the connection time
2017-9-10
aguilera_br
Brazil
jksphoto Posted at 2017-9-10 09:59
Yes! Bluetooth off! I did with my mac so I could record the screen to show you guys the wifi problem!
2017-9-10
Jessie Slem
Flight distance : 820794 ft
HI Guys - I have the same issue. Turn the controller off and on again and then the SSID comes up.
2017-9-10
DJI Diana
Flight distance : 2408 ft
Have you tried to reset the WiFi?  Press and hold the power button for 9 seconds when the RC is on.
What is the firmware of the RC, is it up to date?
2017-9-10
DJI Diana
Jessie Slem Posted at 2017-9-10 15:25
Please try to reset the WiFi and check the firmware version of the RC.
2017-9-10
aguilera_br
Brazil
That is what I do. ;)
2017-9-11
aguilera_br
Brazil
DJI Diana Posted at 2017-9-10 18:22
I did that. Firmware is latest on all devices (drone, controller)
2017-9-11
Marrek
Flight distance : 39170 ft
Estonia
Yeah, I have the same issue. This is a headache and very annoying.  Also, the firmware is latest (RC and drone).
2017-9-11
DJI Diana
aguilera_br Posted at 2017-9-11 19:56
Could you please export the black box data via DJI Assistant 2, upload it to the Dropbox, then provide me with the Dropbox to download it for analysis?
2017-9-11
DJI Diana
Marrek Posted at 2017-9-11 20:59
Could you please also provide export the black box data for analysis? Thank you in advance.
2017-9-11
Marrek
Estonia
DJI Diana Posted at 2017-9-11 23:50
Hi,
Yeah, I tried to export the Black box data but I couldn't. The app did recognise the spark but was unable to export the flight data and the blackbox info. I reinstalled the app and this did not help. I haven't tried the export with different cable, I hope I have time later to do so.
2017-9-14
DJI Diana
Marrek Posted at 2017-9-14 03:36
Hi,
Uninstall the DJI Assistant 2, then disable the antivirus software and firewall, then reinstall the DJI Assistant 2, see if it works. Besides, if it is the same, please try other computers.
2017-9-14
aguilera_br
Brazil
DJI Diana Posted at 2017-9-11 23:34
I would like to reply to you using PM. How can I do it from here?
2017-9-21
fansd6c0b5ac
Flight distance : 155630 ft
Romania
2017-9-21
DJI Diana
aguilera_br Posted at 2017-9-21 18:55
Thanks, received your message, I've forwarded it to our engineers for analysis, will keep you updated.
2017-9-22
