Gimbal Extention Issue
743 3 2017-9-15
Fred D
Flight distance : 56184 ft
So I own an Osmo handle that I use the X3 camera from my Inspire 1 on. I have had it since they were released and I have had zero problems with it. I have used it extensively since I got it. I love this little camera. I purchased another X3 so the Osmo would have it's own camera as I used it so much I didn't want to keep changing the camera back and forth.
I recently purchased the Gimbal Extention so I could mount the camera on a helmet serperate of the handle.
My problem: when I use the Gimbal Extention Cable I loose the vidio image, everything else is fine. I can still shoot video and take pictures, set the camera etc. just on image on the screen.  If I remove the Extention Cable and reinstall it it will work until I turn off the handle, When I turn the handle on again there will be no image again. But when I put the camera back on the handle all is fine the problem is gone.
So I believe the cable is defective, but before I return it I thought I would check to see if this was a known issue and maybe there was a fix.
This is the first issue I have had this any of the accessaries I have bought for my Osmo.
Thanks in advance for any input you may have. Oh my firmware is NOT up to date, it's where I want it, and that is not the issue here.
2017-9-15
DJI Elektra
Fred,if the communication between Gimbal Extention Cable and X3 camera is abnormal, you can try to wipe the copper sheet of the extension with 95% alcohol. I would also recommend you flash your firmware with SD card.
If the problem still exists, please contact our support and send it back: http://www.dji.com/support.
2017-9-15
Fred D
DJI Elektra Posted at 2017-9-15 19:14
https://www.youtube.com/watch?v=jvahCGAtZvU
Thank you for your response and advise. I cleaned the contacts as you recommended and all is good, no more image lose issues
2017-9-26
DJI Elektra
Fred D Posted at 2017-9-26 06:49
Really happy that my advice works. If you have any question, please talk to us. Thanks for your support.
2017-9-27
