Dirk52
Flight distance : 232995 ft
Toffi Posted at 2017-9-18 00:09
It definitely makes no sense to set the home point to the aircrafts actual position, but the update information says: "Added Dynamic Home Point updating, which periodically sets the aircraft's current position as the Home Point."
And that makes absolutely no sense. So I wait with that update cause my Mavic should not land in water because it set a new Home Point There
It makes much sense when the drones postion is used for homepoint when no device is connected. Otherwise you are limited to 50m distance!
Question again at DJI
When comes the the dynamic HP active? Only with a connected device, only when no device is connected or can I set a Option for this? |
