pmshop
Flight distance : 8073271 ft
Micato Posted at 2018-8-27 10:50
Ohh, man I did not want to go that far. I have hack it to FCC so where is the limit? Thank you ! I will try it soon and get back to you! Do you know that latest FW update 100.100. work with DJI Assistant v1.1.2?
GO-TO CORE. ly
Yes, 0.1000 works with 1.1.2
With the controller on and bound, You go into basic settings.
Select Remote Controller along the top menu.
Then at the bottom, click on Control EXP
There you will see the following:
You can see the YAW adjustment.
I have also played with the max ascent and descent speeds as well.
Those are the best for me
Switch to Sport mode and there you can change those settings too (other changes are auto saved)
While you are there, you see this too:
That controls the sensitivity of your sticks.
So if you are blasting out at top speed in Sport mode and see the camera tilt...it is because you slightly moved the stick enough to respond.
I could not fly straight in Sport Mode for long distances to save my life.
I increased the "Pitch/ Roll" and YAW rates to fix it.
The ones displayed are for P-Mode.
Same as before, to change Sport mode...switch to it...you can tell what you are in by the top letters.
P=Positioning S=Sport A=Atti
I used the value "0.6" for Pitch/ Roll and YAW. |
