Terrible video transmission strenght
2391 15 2015-4-4
tylerj
Flight distance : 1595030 ft
Been flying a bunch with my new I1, yesterday I was out on an island, middle of no where and the video trasmission strength was so weak it was worthless. At 200 feet HD transmission would drop out, and the controller is constantly hunting for a signal. I have two controlelrs and consisttanly flying past 200 ft video would start cutting out and freeze and like i said I was no where near civilization.
RC strength was always strong.
Anyone having similar issues?
2015-4-4
lcoleman
Mine is very weak also. While in the air with a clear path to the Inspire, I usually max out at about 1,000 feet before I have problems. If there is anything in the way - trees, building, etc - it gets much worse. I was testing it out tonight by sitting the Inspire on the ground and walking away with the transmitter. At about 200 feet I start getting serious video transmission problems and then just a little farther I drop video totally. Like you, my controller signal is strong at that point but when I lose video totally I also lose all my other data (distance, speed, etc) and then get a Disconnected message at the top.
I notice that the video signal is very sensitive to direction and if I'm not pointing the controller directly at the Inspire the signal drops very fast (even before 200 feet). If I face away from the Inspire so the signal is going through my body or even put my had in front of the controller I lose video signal way before 200 feet.
We are talking 200 FEET while walking or 1,000 feet while flying in best conditions. When I look at the channel I am on it appears to be stable and with little noise. I have tried custom channels and settings, but I see no difference.
I would love some insight into what is causing this. Anyone with similar experiences or ideas on how to improve my transmission would be appreciated.
2015-4-4
w1der
Sweden
http://youtu.be/6BPQxflfQiE
2015-4-5
areischauer
Flight distance : 257382 ft
Make your voices heard.  Dji needs to know about these things
2015-4-5
delas
Flight distance : 1372287 ft
Greece
Signal loss all the time....
2015-4-5
ronnydsosa
Flight distance : 21624 ft
Flew mine yesterday and the video signal dropped at 2.9KM.. Something might be wrong with yah birds.. Just saying...
2015-4-5
benjaminsink
I just got my inspire back from the LA repair facility. The crash was repaired for free under warranty. So today I took my bird out for its first test flight back since its arrival. DJI updated firmware while it was there being repaired. Now first thing I noticed is:
When boots up video quality is very pixelated and choppy, green lines on the screen
It displays the "weak transmission signal" after being 120 ft away (distance wise) not height. When moving the gimbal wih remote it dosent show up on the iPad for about 2 seconds.
Super lag with it as well.  Something isn't right. I never had this problem before the accident. They said they test flew it and it was fully functional but did they test the bird for the distance as well? I'm wondering if there is something they didn't catch...
The bird was in the repair facilty for a month.. I've owned it outside of that for a week.. I really hope this is an firmware issue or something and I don't have to send it in again.
2015-4-8
benjaminsink
My second controller also came to me while I was waiting on my inspire to be repaired. After getting zero help with phone support I figured I would be able to rule out if it was the inspire itself or my remote. I linked the new remote to the bird and had the same issue again and again. It's so strange because it's at a certain distance it just drops and I get nothing but green striped pixelated footage.
2015-4-8
tylerj
Tomorrow I am going to test with different antenna angels and see if that helps, however I am constantly losing signal between 200-250 feet, over 300 ft and it freezes. The latest firmware did nothing to help this.
I'll post something on my results.
2015-4-12
arunmehta
Flight distance : 120909757 ft
i lose 720p video signal at 2200-2500 feet in line of sight now before with custom channels i could go longer
2015-4-12
bvh
Flight distance : 2669265 ft
I lose signal to bird anywhere between 750-1000 feet, line-of-sight.  I used to be able to go further with channel 32.
2015-4-13
Bin Farteen
Flight distance : 174272 ft
Hi,
I had the same issue where my video would just stop transmitting just after take off...
This is what I did and it worked:
On the camera itself, there are two screw holding the connector that connect to the I1.  I loosen those screws just a little bit (maybe 1/2 turn) , to give that connector more heights so that when I mount my camera, the connector touch the I1 .
Never had any problems after that...
Hope this helps
2015-9-4
Machoman
Flight distance : 1036959 ft
Austria
Bin Farteen Posted at 2015-9-5 04:49
Hi,
This is  ...
It stopped transmitting due to signal loss or it just stopped transmitting?
2015-9-5
DJI-Dave
Bin Farteen Posted at 2015-9-4 19:49
Hi,
This is  ...
Good to know. I will take note for future reference.
2015-9-5
Bin Farteen
Machoman Posted at 2015-9-5 04:15
Bad contact between the camera and the gimbal created a signal loss ... After I loosen those screws, i had no more signal loss and always have a good image
2015-9-8
3space
Flight distance : 587359 ft
So, how far can you transmit with this fix having been done?  Thx!
2015-9-8
