Batteries running hot in flight
1016 11 2017-9-25
mikesobola
Flight distance : 46322 ft
My Inspire 1 batteries are running at 110-120 degrees F during fight.  Any ideas what could be causing this?
I haven't flown it for a while and I hovered and did a few slow maneuvers (nothing stressful).  Battery temp was hot to handle and temp readings ranged from 100 to 120 degrees at various points on the battery.
No puffyness.  Looked normal.
They had been in a state of 25% discharge for storage and I charged them for the flight.
2017-9-25
Mark Guille
Flight distance : 2031818 ft
Jersey
These temperatures sound about right. This is a record of one of mine.
[url=][/url]
Mark G.
2017-9-25
Mike, the temperature of the battery is normal, don't worry about it.
2017-9-26
Donnie *
Flight distance : 3636782 ft
Normal battery temps in my opinion .
good lUck
donnie
2017-9-26
mikesobola
Thanks, everyone.  Seems like they are just running on the hot end of the normal range.  I was concerned because the max operating temp listed on the battery is up to 104 F.
2017-9-26
LIVNXXL
Flight distance : 1806125 ft
mikesobola@veri Posted at 2017-9-26 05:28
I believe that is ambient air and not the battery itself
2017-9-26
Mike9129
Flight distance : 4112812 ft
the batteries run pretty hot alrite
2017-9-27
paraviz02
Mark Guille Posted at 2017-9-25 10:35
https://forum.dji.com/forum.php?mod=image&aid=58760&size=300x300&key=d2d5d883df22c1d3&nocache=yes&type=fixnone[/img]
Mark, seems that you have rather boring winters, huh? How come you mainly fly during the summer?
For such a seasoned veteran as yourself, I'd expect all sorts of flight info :-) ...
Beautiful graph.
2017-9-29
paraviz02
We have a weather station that's on Weather Underground next to where we always fly from. If the temperature is near 103º, we won't fly at all. The max operating temperature is simply the ambient temperature.
The aircraft definitely deals with slightly lower temperatures when it's up in the air, but if it is in direct sunlight, the temperature of the various parts is bound to heat up more than the outside air temperature for sure.
Now that you've brought this up, I'm curious if the 104ºF max operating temperature is also including 104ºF in direct sunlight. During the summer, it really seems like the direct sunlight (versus a cloudy day) is a significant impact, even when it is 104ºF both ways.
2017-9-29
Mark Guille
Jersey
paraviz02 Posted at 2017-9-29 12:26
It does look like that, I hadn't noticed. I'm guessing that was from my Tb47, I normally only use it for setting up so it doesn't get much flight time. In the summer months, I guess I fly more so use all batteries.
Glad you like the graph.
Mark G.
2017-9-29
paraviz02
Mark Guille Posted at 2017-9-29 13:14
Gotcha.
So you have like a "prep" set of batteries that you use for the BS work, flight/video adjustments, etc, and then when everything is ready, you switch batteries?
Fun.
2017-9-29
Mike-the-cat
Flight distance : 22488593 ft
Singapore
batteries tend to heat up more towards the end of the flight and if you fly aggressively. In the tropics, the temps can go up to 130F
2017-10-2
