Combining distance from multiple devices.
1149 12 2017-9-25
Tdiggity
Flight distance : 882976 ft
How do I add my flight distance to my user account? And if its by device, how can i combine the distance from each device?
2017-9-25
QuadKid
Flight distance : 482349 ft
You can "sync" your flight records from each device ( go to "Me" in the App >Flight Records> upper right corner tap on the cloud and they should start syncing, and they will be tallied all together for your total distance with DJI.
That is if you remember to do it, don't know how many flight logs I have deleted without syncing them because I had an uneventful flight(s). Usually only keep them if something went wrong or had error messages.
2017-9-25
DJI Thor
Flight distance : 13602 ft
Like QuadKid mentioned, if you are using the same account for all your devices, you can sync your flight record and this woks.
2017-9-26
Tdiggity
QuadKid Posted at 2017-9-25 13:39
That worked....kind of. It shows some distance now but , it shows less then some of my single flights.  I did the sync on device 1 and got around 6000 ft then did the sync on device 2  and it got to were it is now.  I have some flights well over 20,000ft
2017-9-27
Landjet
Flight distance : 61496 ft
I could be wrong, but I believe the app records feet and this site shows meters. It's how mine roughly equates anyway.
2017-9-27
StanfordWebbie
Flight distance : 178018 ft
Landjet Posted at 2017-9-27 12:36
Yup, when I compare the distance on this forum with the distance on my mobile device, they match if I convert the forum from meters to feet (which is what my mobile device indicates).  Next question, however, is how do I get my 2nd quad to show beneath my name on this forum?  I started with a Phantom 3 Adv but now fly my Mavic Pro almost exclusively.  The icon on the forum, however, still only shows the Phantom.
2017-9-27
QuadKid
StanfordWebbie Posted at 2017-9-27 14:15
Did you buy it new? If you did, did you register it under the same account as the Phantom? If you did it should show up.
2017-9-27
Sportbike_Pilot
Flight distance : 10400463 ft
Are you using the same email across all accounts/devices? I ran into that probably having two emails. Had to synch all into one email account.
2017-9-27
StanfordWebbie
QuadKid Posted at 2017-9-27 15:15
Yes, bought new and registered under same account.  In fact, all my Mavic distances show up under my name, but only the Phantom icon shows.  Strange . . .
2017-9-27
StanfordWebbie
Sportbike_Pilot Posted at 2017-9-27 17:32
Yes, same account.  And my Mavic distances show up under my name here, but only the Phantom icon appears.
2017-9-27
Sportbike_Pilot
StanfordWebbie Posted at 2017-9-27 18:28
Yeah that's strange. Maybe mod can assist on this one.
2017-9-28
Tdiggity
Perfect! Thank you Sir
2017-9-28
Landjet
Tdiggity Posted at 2017-9-28 11:18
Reminds me of a Mars orbiter some years ago which was lost. The US portion of the team used English 'pounds of thrust' equations in the programming while the international team used metric 'Newtons'... No one caught the issue... oops...
2017-9-29
